Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 11-07-2023, 01:04 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Default wanted dished 4.350 pistons and 330cfm standard port eheads
have a 4.25 crank and 6.8 rods so ch in the 1.295 range collecting parts for a new IA2 build looking for 30-25cc dish and prefer new before i order but will consider lightly used
eheads in the 72-87cc range 320-340 ported. no offset valvetrain SD BUTLER PKs
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 11-11-2023, 08:49 PM
performerrpm's Avatar
performerrpm performerrpm is online now
Send a message via AIM to performerrpm
theres some 330cfm heads on fb right now...
Old 11-11-2023, 11:07 PM
slowbird's Avatar
slowbird slowbird is offline
Piston here
https://forums.maxperformanceinc.com...d.php?t=761285
Old 11-21-2023, 07:39 PM
GTO FIREHAWK JOHN's Avatar
GTO FIREHAWK JOHN GTO FIREHAWK JOHN is offline
Default 4.350 bore Ross pistons
Hey I have a set of pistons as I took my 535 apart to change a few things, cam & go thru the heads as I was getting oil in cylinders through intake valves. Now that it’s out I’ve ordered new 4.360 so I can clean up everything
They have light scratches on walls/Skirts if you want I can take picks of each 1
Still waiting for my ordered set
I’m not sure what there worth, let me know if your interested, I can send you the piston spec sheet
ID:	623569   Click image for larger version
1970 GTO Judge. New times 10.60/126 with a 1.45 60ft.
2002 FIREHAWK-conv. 6-sd.
1969 Carousel red Judge Ram Air IV
722 heads. 4-sd. Black interior.
Old 11-22-2023, 09:49 AM
I might be interested but pretty sure I’m going to leave the 540 intact and and the new ia2 I have is supposed to be 4.345 bore but I will measure
What compression did you have with what Cc heads
1964 540 gto
Old 11-22-2023, 09:20 PM
Default SD Edelbrocks 72cc
Have Dave’s top end package with 72cc (345) heads and these Ross dished pistons for 10.9 comp.
I really need a hurst Dual gate shifter which I will convert to shift 4-sd as I’m installing a 4L80E that’s all built now with a matched PTC lock up converter that Ouched me bad in the Pockets!
is yr 3.45 bore finished hone
