I have a new galvanized tank and stainless tank that I would like to keep fresh looking as long as possible. What are the preferred methods to keep the tanks nice looking? Clear coat, wax, other? thanks in advance.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
What are the tanks used for?
Custom and restoration work in Iowa 38 years. Bias ply tire truing, louvering, metal shaping, machine work, painting etc. See my albums. |
one is a 64 abody and the other 69 abody. Just be car show, occasional cruise type stuff.
I used a clear from POR15, been on the tank for 5 years now and still looks great, can either brush it on, or thin and spray. It's fairly thick and it flows out nicely so brush works really good.
http://www.por15.com/GLISTEN-PC_p_45.html
64 Lemans hardtop 4spd, buckets |
Never really like the use of clear coats as you can always tell. Unless you are going to use your car as a daily driver, a yearly coat of wax will usually do the trick. Simply wipe the new tank with a solvent to take off any of the greasy coating that is usually left. Then apply a liberal coat of wax, just like you would on the exterior of your car. As soona as it dries, wipe it off thoroughly. This will keep it looking original and like the day it rolled off the truck.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
I'd try wiping it down with Gibbs rust inhibitor.
The galvanized one you should clear coat & the stainless one you can use a product called sharkhide it works very good & you only need to do it once a year.
