Old 03-02-2024, 11:13 PM
Elarson's Avatar
Elarson Elarson is offline
Default '67-68 Firebird PS Pump Brackets?
I'm looking for the exploded view (from the factory parts manual) of the 1st Gen. power steering pump and alternator mounts. I bought a '75 Firebird that has the early PS pump assembly and I think I'm missing some spacers and have wrong alternator brackets. I'm hoping the exploded view will make it all clear.
Eric
Old 03-03-2024, 07:20 AM
chuckies76ta's Avatar
This is out of my 68 Firebird factory manual.
Old 03-03-2024, 09:18 AM
Elarson's Avatar
Exactly what I needed. I can see that I'm missing a couple of pieces. I also see where the little 3-bolt plate (at the bottom of the alternator) is supposed to go.
Eric
Old 03-03-2024, 10:17 AM
steve25 steve25 is offline
I could be wrong, but isn’t the only difference in the later setups the bigger one piece top Alt bracket that also bolts to the side of the intake besides at the water outlet?
Old 03-03-2024, 11:19 AM
Elarson's Avatar
The early bracket (seen in post #2) is an aluminum casting. The later bracket is stamped steel and the pump is different. And the early one sets the pump pulley closer to the head by about 1/2" (my recent ah-ha discovery from searching old threads.
Eric
The Following User Says Thank You to Elarson For This Useful Post:
Old 03-03-2024, 11:56 AM
71 and later also have an extra bolt for the extra hole on the heads. (I think)
So depends on the timing cover you are using. (for spacing usually)
Old 03-03-2024, 06:53 PM
Elarson's Avatar
Thanks to chiefbigb for sending me pix of both varieties.
Eric
