Old 11-21-2020, 03:57 PM
RAIV55 RAIV55 is offline
I haven't had any issues with Powerbond dampers on the ones I've used. Other low cost dampers that given good service has been Pioneer with the snap ring and the Summit brand.
ATI Superdampers are what I recommend when asked. I know they are more expensive but what is the extra $200 to protect other high dollar parts?
Monty Frerichs
B&M Machine
Box Elder SD
Old 11-21-2020, 05:02 PM
mchell's Avatar
mchell mchell is offline
I looked at the ATI balancer, but it appeared they didn’t have a 4 bolt style available? The one I spun i believe is a pioneer with the snap ring...basically built exactly like the powerbond unit
Does the ATI clear the oil pan lip and how’s the fit on the crank snout?
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 11-21-2020, 07:05 PM
AG's Avatar
AG AG is offline
I use BHJ and they have worked well.
Old 11-21-2020, 07:20 PM
Dragncar Dragncar is offline
The place to buy a 4 bolt Pontiac SFI US made balancer that will clear the lip and work on all Pontiacs even with A/C is Nightmare Performance. They sell the BHJ balancer that he had a custom run made that will work on any Pontiac.
He paid a lot of money for the buy in but he has them in stock. I paid about 450$ for mine and if you go straight to BHJ they are close to 600$.
You need to have a 'exact" measurement of your snout down to .000 so he can match up with ones he has already measured so you get the correct press fit.
He is the guy, call him up. They are not "one size fits all".
Old 11-21-2020, 08:51 PM
With a new balancer, mark the hub and ring, so you can keep an eye on them and catch any obvious slippage.
Bill Nye.
Old 11-21-2020, 10:00 PM
Schurkey Schurkey is offline
The only time I ever exploded a torsional damper, the engine spun a bunch of rod bearings not long afterwards. The engine was assembled by morons, lasted about a year and a half.
Did the faulty damper cause crank problems?
or
Did crank problems overload the damper causing it's failure?
Since that time, I've always been squeamish about shoving a new damper onto a crank when the old damper failed. Seems like a good time to check the bearings and maybe the flywheel/clutch/flexplate...
Old 11-21-2020, 10:11 PM
To your original question I looked at two balancers I have the key way is about 80° they both stop at 50° and then has 90° so it’s just a close estimate.
Old 11-21-2020, 11:04 PM
mchell's Avatar
or
The dampener certainly wasn’t “exploded” by any stretch...it did slip.
Old 11-21-2020, 11:07 PM
mchell's Avatar
Thanks.....
Old 11-22-2020, 01:20 AM
77 TRASHCAN's Avatar
Anyone else care to post balancer brands that are good... or bad? Sounds like some more education on the subject would be good, if it’s ok w/ Mike?
Shut it off
Shut it off
Old 11-25-2020, 01:59 PM
1969400HO's Avatar
Interesting thread here.
My experiences, If TC (cam & crank) is at Zero with No Adv-Ret, offsets, the (installed on snout) damper should then display the “Zero” groove-line mark at the TC-Cover’s pointer-finger line / edge.
I’ve seen where the cover finger was wrong and or the damper was wrong also, at OEM instal of all parts.
It was a matter of figuring and get the proper pieces to make it sync-align, else would so cause confusion.
It all should align rather simply as designed!! (in a perfect I dream of Genie show world).
Work around I also seen is the inner mechanics of TC setting once you Do have this TC set, then THAT is the bottom line!!
You will need to make the damper its “new Zero” TDC mark.
Which is cosmetically Wrong yet the engine doesn’t care!
Just make your new Zero line mark, on the damper, like a Butler damper tape placement on it etc.
And finish the task or go gather the correct TC cover or/and damper combo pieces..
And Yes these old damper have old rubber inserts Do have a limited life span, I had one on my Honda accord spin slightly on me causing a lot of havoc & days of troubleshooting my electrical system. (poor battery charging issues-next morning No starting)
Hope this helps.
Don’t fall for the banana in the tailpipe!!
Old 11-25-2020, 02:25 PM
Lee's Avatar
Lee Lee is offline
I use a chisel, to make reference marks on the outer and inner.
I also now make a paint mark on the crank pulley, inline with the timing mark. Then, when checking timing, I can see if there has been slippage.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 11-25-2020, 04:08 PM
The timing chain advance/retard has NO bearing on the TDC mark of the torsional damper lining up with the TDC mark of the timing pointer. TDC #1 is TDC #1, no matter where the cam is positioned.
Best to avoid the (sharp) chisel, as the sharp indentation makes a perfect stress-riser potentially leading to a crack.
I've put marks in dampers using a center-punch; but then I set a small ball-bearing on the punchmark and whack it with a hammer to create a rounded impression with surface compaction, to avoid cracking.
Old 11-25-2020, 04:56 PM
1969400HO's Avatar
Well....should have removed pulley before I posted
See pic....definitely spun
Look at the fresh shiny spots...
https://share.icloud.com/photos/0ww5...NZbYJ1OtlnwVjg
"The timing chain advance/retard has NO bearing on the TDC mark of the torsional damper lining up with the TDC mark of the timing pointer. TDC #1 is TDC #1, no matter where the cam is positioned.”
The statement was for OEM straight up cam crank align, as in whole task-job in this matter, to Clarify logic and clocking degree mechanics, that reflects including the OEM proper damper to Pointer alignment .
Offset in cam is irrelevant to damper and goes “almost” without saying, unless a Soul on the thread needs things Spelled out a little deeper--obviously.
After 45 years as an engine builder-mechanic and the winningest engine Still in my region bet Ive learned this within 3 months of understanding in the 70’s.
Like I said if dampener is OFF then “Butler “TAPE” remark it . READ the whole statement .
thx
Old 11-25-2020, 05:32 PM
Lee's Avatar
Lee Lee is offline
Not like it is a crank gear, no real stresses on THAT part of damper. Being doing that for over 20 years without an issue. Doesn't need to be deep, just enough to make it obvious.
Old 11-26-2020, 05:28 PM
unclescratch's Avatar
unclescratch unclescratch is offline
Default slipped balancer
I had one that had slipped about 5/8-inch. Verified that with a piston stop and rotating by hand in both directions. New balancer checked 'perfect' using same technique.
Old 11-26-2020, 09:22 PM
mchell's Avatar
Lord....that’s a range of responses
New balancer is installed, all back to normal again.
I ended up with a Romac balancer due to the powerbond not being in stock.
As others have noted with the Romac, I had to bend the lip of the oil pan slightly to clearance the balancer hub. Other than that, no issues.
Thanks for the feedback
  #38
Old 11-27-2020, 10:40 AM
chuckies76ta's Avatar
I'm running the ATI one. From what I understand when you get in the upper H/P levels, its good to move to a more reliable balancer. I had to remove a small portion of the timing tab. I had not issues with oil pan lip and I just took my pulley and drilled 3 new holes as the balancer uses 3- 3/8" bolts versus 4-5/16" bolts. I run the powerbond on 2 engines with 600 hp and 600 T with no issues so far.
Charles
  #39
Old 12-01-2020, 08:56 PM
68azbird 68azbird is offline
piston stop on number 1 ?
It is easier to fool a man than it is to convince he has been fooled
