Old 01-26-2024, 07:48 PM
vicgto vicgto is offline
Default Will a 1975 Monte Carlo 10 bolt fit a 72 GTO
I have been looking for a 10 bolt 8.5 rear end as I'm not sure how long my 8.2 BOP axle will last and I dont think it makes sense to put money into it. My friend has a 1975 Monte Carlo rear end, will it fit my 1972 GTO?
1972 GTO
468 2 Bolt Main w/Eagle rotating assy
SD Ported 295 KRE D Ports 10.8 CR
OF Hydraulic roller w/ 1.65 stainless rockers
Performer RPM Intake
Holley 3310 780 Vacuum Secondary
TH400 with 10" Continental Convertor
8.2 BOP 4 pinion 10 Bolt with 3.36 gears
11.428/118.95/1.618
Old 01-26-2024, 08:06 PM
No, the '73-77 A body r/e housing has a wider spread between the two upper control arm mounts. The overall width of the '73-77 A -body rear also near an inch wider than your LATE PONTIAC 8.2 10 bolt.
Know these rears very well, have built up near 2 dozen '73-77 A-body rears & over 350 71-72 8.5 A-body rears.
The Following 2 Users Say Thank You to 'ol Pinion head For This Useful Post:
Old 01-26-2024, 09:27 PM
Thanks Ol pinion, this 12 bolt rear end is currently on Kijij but the cover looks different than the usual 12 bolt cover, any idea what it is?
1972 GTO
11.428/118.95/1.618
Old 01-26-2024, 10:05 PM
Default Oldsmobile 'O' type rearend
12-bolts in the cover but 10-bolt guts.
Decent rear-ends but no stronger than a normal 10-bolt.
Old 01-27-2024, 12:39 AM
Attachment 627256
8.75 (?) out of a ‘65-‘7O B-body. Parts are getting very difficult to find for them. Nothing wrong with a correctly built 8.5; they are a strong diff.
Dr. Thomas Sowell
The Following User Says Thank You to hurryinhoosier62 For This Useful Post:
Old 01-27-2024, 09:34 AM
And remember the Yoke from a 65-70 Big Car fits the Chevy 12-Bolt, so you can enjoy the Pontiac size U-Joint.
Old 01-27-2024, 03:35 PM
400 Lemans's Avatar
400 Lemans 400 Lemans is online now
65-70 yoke is 28 spline. 71-76 is the 30 spline.http://forum.jdrace.com/viewtopic.php?t=526
