Old 10-13-2010, 01:59 PM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
Lynn, Tony is taking a RA V headed engine to Engine Masters?
That should be cool!
Maybe next year? Believe me I am trying hard!
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
lmc3470@aol.com
www.ChemicalManagementIndiana.com
317-260-3486
  #62
Old 10-14-2010, 10:57 PM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
SPEECHLESS!!!!! Tom, that looks like a lot of head for a street car no? (like i should talk)
Time to get back in the game...
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored)
1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505
1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS
AC Cobra Kit Car 521 670 HP/715 Trq
LOOKING FOR V PARTS !!!!!!!!!!!!
  #63
Old 10-14-2010, 11:16 PM
Port appears similar in diameter to a NON cj 429/460 Ford and shaped better.(I got a peek at a RA5 the other day). I wouldnt think they were too big for a street car unless you were stictly shooting for best mpg.
  #64
Old 10-15-2010, 09:29 AM
We redesigned the heads about 6 months ago to be much smaller than even before. We then do exactly the way as Pontiac by running the valve pocket cutter down the throat of the intake valve to get the diameter we desire. Tony needs a smaller valve pocket to start off with for porting, but that would affect our "as cast" customers. So to keep from having two different castings, this allows us to provide a smaller throat area with material for porters without sacraficing flow for the "as cast" customers. Pontiac really knew what they were doing in this respect making castings to match the greatest possible number of applications.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
lmc3470@aol.com
317-260-3486
  #65
Old 10-18-2010, 11:08 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Default A few more pics
Some clean up shots of combustion chamber and intake ports. Seat work is next then pushrod tubes.
  #66
Old 10-18-2010, 11:13 PM
2nd try to load pics
ID:	221617   Click image for larger version
ID:	221618   Click image for larger version
ID:	221619   Click image for larger version
  #67
Old 10-19-2010, 11:28 AM
Region Warrior's Avatar
SWEET!
  #68
Old 10-31-2010, 08:41 PM
Some progress...
.406" pilot hole for pushrods centered on the rocker stud hole. Will install at least a .500" hole on this set.
ID:	222983   Click image for larger version
ID:	222984   Click image for larger version
ID:	222985   Click image for larger version
  #69
Old 10-31-2010, 08:43 PM
tom s tom s is offline
did I send you guide plates yet?Tom
  #70
Old 10-31-2010, 08:49 PM
Overall this 455 looks good with a set of V heads and single plane intake. Will have to mill a bit off the intake to achieve a optimum fit.
ID:	222987   Click image for larger version
ID:	222988   Click image for larger version
  #71
Old 10-31-2010, 08:51 PM
Tom,
I did not receive guide plates.
  #72
Old 10-31-2010, 09:18 PM
will get them out tomorrow.Tom
  #73
Old 10-31-2010, 09:31 PM
Ron H's Avatar
Ron H Ron H is offline
Looks great Jim. Can't wait to hear it's performance.
68 Firebird
Are you running with the wind or breaking it?
  #74
Old 11-01-2010, 10:49 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Looks like it might even fit under a Shaker!
Skip Fix
  #75
Old 11-01-2010, 11:03 AM
SD421's Avatar
SD421 SD421 is offline
Jim, The first pic.Just curious as to the "small valley pan" that you have welded down and bolted in.
BTW looks pretty.
Don
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
  #76
Old 11-01-2010, 11:25 AM
slowbird's Avatar
slowbird slowbird is offline
I know this sounds crazy but if someone could figure out a way to put o-rings around the pushrods at the top and bottom instead of using a tube, I bet that would help flow out.
  #77
Old 11-01-2010, 11:26 AM
slowbird's Avatar
BTW looks pretty.
Don
It is a lifter bore brace.
  #78
Old 11-01-2010, 02:07 PM
We designed the single 4 intake to be the same height as a stock Pontiac when used with our heads.
Lynn
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
lmc3470@aol.com
317-260-3486
  #79
Old 11-01-2010, 02:12 PM
This is very close to becoming a reality, but requires precision engine building and cannot be installed for a "bolt on" application. There is more technology here than you think. We can also use this push rod hole as a "support" for the push rod to eliminate flexing. Many race engines are now using as big as 9/16 push rod diameters to handle valve train flex and paracytic losses. What if you had a bearing fit for a smaller pushrod? All I am saying right now, but I love this kind of stuff!
Lynn
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
lmc3470@aol.com
317-260-3486
  #80
Old 11-01-2010, 05:32 PM
gearbanger's Avatar
gearbanger gearbanger is offline
I don't really see that being possible because the rocker goes througha sweeping motion and the pushrod angle is constantly changing. Good thought though. I really don;t see the pushrod tube being a big problem either. Maybe in a max effort deal where every cfm counts, but for the purpose I think Lynn has in mind, I don't see it as a factor.
