Old 06-05-2022, 07:40 PM
Rugratman's Avatar
Rugratman Rugratman is offline
Default Power steering pump pressure
Is it possible for the pump to make too much pressure or not enough pressure.
I have a quick ratio box and my replacement pump.
I am getting a belt squeal at 3000 rpm. Nothing before 3000.
New pulleys and belts.
When I changed the pump I never considered the pressure required. If that is possible.
Alignment is correct.
Sent from my SM-G930V using Tapatalk
........I'm just learning as I go.......
Old 06-05-2022, 08:56 PM
DavesGTO's Avatar
DavesGTO DavesGTO is online now
Had that problem before,bought a repro power steering belt and that fixed it.
The Following User Says Thank You to DavesGTO For This Useful Post:
Old 06-06-2022, 08:46 AM
Half-Inch Stud's Avatar
My junkyard "research"from pulling pumps and their regulators told me that Bird had the low psi (1100?), A-bodies had medium (1200?), and big cars had high psi (1600?).
Think i went with 1600 psi in one of my birds and it was too twitchy. Nice though in a 68 GTO.
Old 06-06-2022, 08:49 AM
Cogged V-Belt is the best remedy for PS squeal.
Is the new PS belt you mention bottomed-out on the PS or crankpulley?
Old 06-06-2022, 04:47 PM
Rugratman's Avatar
I will check that. They seem to be seated flush. Remanufactured gm pulleys and gates belts.
When you order a new pump, do you need to be pressure specific?
Did I make a mistake?
Old 06-06-2022, 05:08 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default Pump pressure
Summit sells a kit to adj pressure.
It goes into output port on pump.
The kit contained shims to control
Bypass volume and thus lowered output
Pressure.
When I put a new pump in I did not know to
Pull old output fitting and transfer to new pump.
Kit resolved issue.
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
The Following User Says Thank You to 68 Firebird For This Useful Post:
Old 06-06-2022, 08:33 PM
OG68 OG68 is offline
Jim Shea Steering papers regarding pressure and flow rates.
http://jimshea.corvettefaq.com/wp-co...s-09OC2013.pdf
http://jimshea.corvettefaq.com/?p=572
2007 Cadillac SRX
