Old 01-10-2024, 01:32 AM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
Default almost 24 years in the making. My engine is finally done
I joined the board back in 4/2003 and my first post was asking what heads to use on my engine build. Well life and other toys got in the way and the engine was put on the back burner. In may I finally brought the block to shop and told them to put it together and yesterday I got the call that it was finally done. It's a 1971 400 that I bought off ebay as a non runner and no idea what it was originally in.
So now it'll be going in my 67 Firebird. We stepped it up to a 461 running Edelbrock heads and Victor intake, comp cam, SCAT rotating assembly, roller rockers and lifters on pump gas putting out 561 hp and 611 lbs of torque. https://youtu.be/BVjqcRvOyI4
ID:	626329   Click image for larger version
ID:	626330   Click image for larger version
ID:	626331   Click image for larger version
ID:	626332   Click image for larger version
67 Firebird Convertible
The Following 5 Users Say Thank You to jwcfbd For This Useful Post:
Old 01-10-2024, 01:36 AM
jwcfbd's Avatar
The final product.
ID:	626335   Click image for larger version
ID:	626336   Click image for larger version
ID:	626337   Click image for larger version
ID:	626339   Click image for larger version
The Following 10 Users Say Thank You to jwcfbd For This Useful Post:
Old 01-10-2024, 02:05 AM
Dragncar Dragncar is offline
Sweet, persistence paid off.
Old 01-10-2024, 08:22 AM
sdbob sdbob is offline
Congratulations, wish you all the luck. Never quit!
The Following User Says Thank You to sdbob For This Useful Post:
Old 01-10-2024, 08:29 AM
AG's Avatar
AG AG is offline
The Victor intake will not fit under your stock hood unless you don't run an air cleaner. You will need to get a cowl hood or some type of scoop.
The Following User Says Thank You to AG For This Useful Post:
P@blo's Avatar
P@blo P@blo is offline
Took longer because you paused the build, life happens. Nice engine indeed and you should be proud. Sounds killer too.
What pistons?
The Following User Says Thank You to P@blo For This Useful Post:
Old 01-10-2024, 09:58 AM
72projectbird's Avatar
That's a stout setup! Congrats on getting it done, and be sure to do a celebration burnout for us!
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 01-10-2024, 10:26 AM
61-63's Avatar
61-63 61-63 is offline
You are about as fast as I am getting these things done. Congratulations on finishing it and it looks like a neat engine.
The Following User Says Thank You to 61-63 For This Useful Post:
Old 01-10-2024, 11:57 AM
jhein's Avatar
jhein jhein is offline
That's fantastic. It looks and sounds great. What cam are you running? Any porting to the heads?
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 01-10-2024, 01:14 PM
jwcfbd's Avatar
That is a concern for sure. I've gotten mixed opinions if it'll fit or not. Hopefully it will with a drop base cleaner.
Old 01-10-2024, 02:09 PM
jwcfbd's Avatar
Yeah heads where ported by Butler for 325+ cfm and cam I need to figure out
The Following User Says Thank You to jwcfbd For This Useful Post:
Old 01-10-2024, 03:32 PM
jwcfbd's Avatar
What pistons?
It's a SCAT rotating assembly 41661BI with ICON forged pistons.
Old 01-10-2024, 03:52 PM
performerrpm's Avatar
man im glad i aint the only one...lol. im just now getting around to diggin out parts i bought in 08 for my 455 build....lifes a bitch @ times....but i did manage to get more parts here an there an put on the shelf for later
The Following User Says Thank You to performerrpm For This Useful Post:
Old 01-10-2024, 04:35 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
Well done, looks amazing! sounds good and makes great power!
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
The Following User Says Thank You to kyle_blake For This Useful Post:
Old 01-10-2024, 05:28 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Nice engine package!
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
The Following User Says Thank You to hojs69 For This Useful Post:
Old 01-14-2024, 08:25 AM
1967SC's Avatar
1967SC 1967SC is offline
Congratulations on the never give up attitude.
Good luck .
1967 GTO Sport Coupe
49,xxx orig.miles
Champagne/Parchment
30 Original Owner Ordered PHS Documented Factory Options
Second Owner
The Following User Says Thank You to 1967SC For This Useful Post:
Old 01-15-2024, 01:57 PM
Jim Moshier's Avatar
that's a stout running engine Congrats on finally completing it! You will enjoy the memories.
Jim Moshier
1962 Catalina 389
The Following User Says Thank You to Jim Moshier For This Useful Post:
