Old 12-08-2005, 11:08 AM
Steveski Steveski is offline
Default '68 exhaust manifold leak
I replaced the blown out passenger side exhaust manifold gasket on my '68 400YS, but was told that it is a bad design and will blow out again. Apparently a bolt is missing that was added in later years. Any solutions to fix other than installing headers? Would steel gaskets help?
Old 12-09-2005, 04:37 PM
engineer engineer is offline
always used steel gaskets on cast manifolds except ram air, not bad design. will work if flat and torqued uniformly.
