Old 02-05-2023, 11:05 AM
joes455 joes455 is offline
Default Engine breakin oil
OK so currently added 5qts of royal purple break in oil ,I need 2 more quarts .Can I add regular oil to the mix,or just get the 2 qts of royal purple
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 02-05-2023, 11:09 AM
yellow1098's Avatar
yellow1098 yellow1098 is offline
With a hyd roller 2 quarts of whatever good oil you’d run would be fine
The Following User Says Thank You to yellow1098 For This Useful Post:
Old 02-05-2023, 12:18 PM
More concerned about rings sealing
Old 02-05-2023, 01:19 PM
Steve C. Steve C. is offline
From their website...
"Royal Purple lubricants are fully compatible with mineral or synthetic oils. No special procedures are necessary when switching to Royal Purple. We recommend against intentionally creating a mixture of different brands or product lines of engine oils."
Old information here:
Old 02-05-2023, 08:06 PM
geeteeohguy's Avatar
If you are breaking in a flat tappet cam, NO. Regular oil has too many detergents that will wipe the break in lube off the cam and lifters and hold it in suspension. Spring for the extra 2 quarts and play it safe.
Jeff
The Following 2 Users Say Thank You to geeteeohguy For This Useful Post:
Old 02-05-2023, 08:41 PM
Added 1 qt of vr1 racing oil ,it was just enough.I don't understand why anyone would want to add synthetic oil to a break in oil,that sounds like a big no no for ring seating
