Old 11-10-2022, 02:50 PM
roy381 roy381 is offline
Default 67 gto mini starter
Hi folks, Having a hell a time with a Hitachi starter. Solenoid hitting the header. And it's not clockable. What works with Dougs D port headers on 67 gto.
Thanks in advance
Old 11-10-2022, 03:18 PM
ID67goat's Avatar
ID67goat ID67goat is offline
I like my Robb MC starter....
The Following User Says Thank You to ID67goat For This Useful Post:
Old 11-10-2022, 03:44 PM
jhein's Avatar
jhein jhein is offline
Don't know about headers but I have the Powermaster 9510 with RA manifolds and it fits fine. It has infinite clocking so it should work. People seem to really like their Robb MC starters too which also have infinite clocking.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 11-10-2022, 05:11 PM
A friend has a 67 but he has Dougs round ports. But they are shaped different. He has the powermaster 9410
Old 11-10-2022, 05:25 PM
Gator67's Avatar
Gator67 Gator67 is offline
I have RobbMc starters on 3 Pontiacs....reliable, compact and easy to clock however you want.
Old 11-10-2022, 05:40 PM
tom s tom s is offline
IMIs are clockable.Tom
Old 11-10-2022, 06:32 PM
Default starter
Are any of these a 67 with Dougs D port?
Old 11-10-2022, 07:01 PM
Gator67's Avatar
One is a 67 GTO with RA exhaust manifolds…very tight in there with OEM starter
Old 11-10-2022, 09:04 PM
AG's Avatar
AG AG is offline
I have a stock starter on my '72 A body with RA manifolds with no problems but is tight, I'll switch to a mini if it goes. I have a Hitachi style on my '67 Fbird race car and the positive stud is 1/8" away from the header and I've never had a problem. I have a RobbMC starter with pinion support ready to change it if it goes.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 11-10-2022, 10:20 PM
ID67goat's Avatar
Mine is 67 with Doug’s O-port. Had a non-clockable Powermaster in it before the Robb MC and it fit fine also…
Old 11-10-2022, 10:26 PM
carcrazy carcrazy is offline
Had multiple Robb Mc and they have worked well!
Old 11-11-2022, 03:05 AM
lust4speed's Avatar
Had three 67 GTO's all with Doug's headers. Somehow ended up with three different mini starters and all fit without a problem. IMI, Summit, and Powermaster starters. Prefer the IMI over the others. Last year had to send back two Summit starters because of the mounting blocks being drilled wrong.
Mick Batson
Old 11-11-2022, 11:29 AM
ZeGermanHam's Avatar
I have a Powermaster 9510 in my 66 GTO (same layout as 67) with Doug's D-port headers (p/n D564). It fits great and there is all kinds of room. The 9510 is infinitely clockable, but I didn't have to change how it came from the manufacturer. Fit perfectly right out of the box.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 11-11-2022, 11:35 AM
zippy's Avatar
zippy zippy is offline
Have that same starter on my 455 for many many years. Hooker headers. No clearance issues and no hot start issues. 10.6:1 comp. The Stock HD Pontiac starter heat soaked so bad it was embarrasing at a gas pump LOL. 30min cooldown at least before she would crank
Dan Pesonen
"If it ain't broke, modify somethin till it is"
Old 11-11-2022, 02:33 PM
Thanks for the responses folks much appreciated.
ZeGermanHam thanks for the pictures. I'm going to give the powermaster a shot.
The Following User Says Thank You to roy381 For This Useful Post:
Old 11-17-2022, 11:15 AM
JUDGE3 JUDGE3 is offline
yep mini starters fit great, crank great to! about have to use a mini with headers.
but......with no starter pinion support, stay on top of the fitment. if you can find a pontiac mini with pinion support that would be golden.
