Why can I not find this????
Looking for the plate to cover this EGR opening but can’t find this shape. Can anyone source one?
Because it's not an EGR passage, it's where the hot air choke stove for the automatic choke operation bolts on.
The EGR is vertical, and behind the choke stove in this picture. This is a 1973 Firebird factory cast iron manifold. Edelbrock did have a cast aluminum plate to block that passage back in the late 70s/early 80s, I'm not certain if it's still available, or you ca take a piece of 1/4 inch steel, and fabricate one from scratch.
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated Last edited by Sirrotica; 06-20-2022 at 10:49 PM. |
The Following 3 Users Say Thank You to Sirrotica For This Useful Post: | ||
Yup. Buy a gasket, put it on a piece of flat steel, shape the steel like the outline of the gasket. Drill two holes. Paint to suit...but the paint may burn off.
The Following User Says Thank You to Schurkey For This Useful Post: | ||
3/8” aluminum plate would be easier to drill, cut and shape than steel.
Easy project you can do with a drill, hacksaw and a file, using either steel or aluminum plate.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
The Following 2 Users Say Thank You to Holeshot71 For This Useful Post: | ||
Thread Tools | |
Display Modes | |
