Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 01-18-2022, 08:57 PM
4dblnkldude's Avatar
Default WTB - Modified dual snorkel air cleaner
I know this probably a longshot but does anyone have a modified dual snorkel air cleaner assembly that is modified to sit on a Holley carb? Or does anyone know how to easily modify it? My buddy has a 70 lemans he would like to put it on, instead of a regular parts store 14" bull crap one. Would be good if it was all black, no chrome lid, he hates chrome. I just figured I'd post this before we butcher up a re-pop one.
Old 01-18-2022, 11:41 PM
Half-Inch Stud's Avatar
I too would love one for a 1050 Dom fit.
Old 01-19-2022, 01:34 AM
Dragncar Dragncar is offline
I ran a Holley 3310 with a original GTO duel snorkel in High School.
Old 01-19-2022, 10:34 AM
How does it need to be modified to fit a Holley?
Old 01-19-2022, 11:56 AM
chuckies76ta's Avatar
Are you doing a 4150 or 4500? I built a dual snorkel for my 4150 quickfuel. I just modified my 76 Air cleaner assembly. I also found myself some of the cylindrical cone air cleaner. I like the looks of the 455 ho air cleaner.
Old 01-19-2022, 12:26 PM
Mike Davis's Avatar
Where did you find the air filter? Been looking for a cone style for the TA.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 01-19-2022, 12:33 PM
Check this thread. https://forums.maxperformanceinc.com...ght=Wfo+airaid Been so long ago.
https://www.airaid.com/concept I would have to measure mine or find part numbers. I just took my lid and cut it for the top. Sit nicely inside the shaker.
I do have the bigger one, but not gonna use if your interested.
Old 01-19-2022, 01:44 PM
The part number on the one I bought that I'm using is 801-452 and the spare one that I have that I would sell is 801-456.
Name:	airaid air cleaner.jpg
Old 01-24-2022, 07:51 PM
pontiacjeff pontiacjeff is offline
I built one and will sell it to you. It has a aftermarket drop base and will fit a holley.
Jeff Ianitello
Old 01-24-2022, 10:41 PM
PM sent.
Old 01-25-2022, 07:01 PM
unruhjonny's Avatar
Originally Posted by 4dblnkldude View Post
... I just figured I'd post this before we butcher up a re-pop one.
Are the Lemans/GTO aircleaners that hard to find?
I'd think a used one could be had cheaper than a repop.
I know the service replacement 71-72 'Ram Air' air cleaners clear a holley - but never tried fitting any other factory air cleaner on top of a Holley.
1970 Formula 400
Old 01-25-2022, 10:56 PM
Do the ram air cleaners have dual snorkels?
Old 01-26-2022, 12:59 AM
unruhjonny's Avatar
they are designed to seal up to the hood with rubber boots.
1970 Formula 400
Old 01-26-2022, 09:46 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
I have an older 750 double pumper that I run on my 71 GTO once in a while. The stock dual snorkel fits just fine without any mods fwiw.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
The Following User Says Thank You to Holeshot71 For This Useful Post:
Old 01-26-2022, 09:45 PM
Man, I'm learning alot in this thread! So if we cant get a used one and he orders a repop he should order one for a 70-72 GTO/Lemans?
Old 01-27-2022, 07:13 PM
Holeshot71's Avatar
Can’t say whether or not the Repop will fit, never used one. I can only speak from my experience with the 70 to 72 GTO dual snorkel. The Firebird 400 dual snorkels of the same years have a drop base that may not work. Those are easy to identify, they have a indentation in the back of the base to clear the distributor. Check out the picture for reference.
Old 01-27-2022, 09:44 PM
Can’t say whether or not the Repop will fit, never used one. I can only speak from my experience with the 70 to 72 GTO dual snorkel. The Firebird 400 dual snorkels of the same years have a drop base that may not work...
Correct, the factory 2nd Gen bases (both T/A & Formula) are 1 1/2" drop & the center area will not clear the bowls on a center hung Holley. Have restored several early 2nd Gen T/A & Formula bases that previous owners hacked on to clear the center hung bowls of their Holley. On a '70 Pontiac A-body my suggestion would be to buy the PartsPlace dual snorkle 70-72 GTO repo. Nice clean originals tend to run more $$$.
