Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
12 bolt Moser,428 Short block, round Port headers
Moser 12 bolt rear end a body Moser 33 spline axles, true trac posi diff, motive 3.73 gears, aluminum Moser diff cover, 1/2 inch studs, built by Moser, $3000.
Round Port headers 68-72 GTO, 70-81 f body $400. Bop turbo 400 manual valve body great trans was in my car several years running 10.50s just pulled $1000. 10" Coan converter 3800 stall. $600. 428 Short block, bored over 0.30 new needs assembled new king bearings, total seal Rings, Forged pistons, eagle rods, Arma steel Crank all balanced, new balancer, gasket set, new cam bearings. Double roller timing chain , comp cam , $4000. 419-230-6681 |
what brand/part# are the headers? got any pics? location?
No name on headers.
Built-in the early 70s |
I'm in Ohio
some pics of the headers would help to see the condition or for others determine what they are.
Text me at 419-230-6681
Could not download pictures |
Try uploading a couple Headers photos Here: hit the button below " Go advanced " will pull from your photolist, easy.
428 is 4 bolt main ,new ARP studs
In regards to the 428 build specs on the cam and is all the machine work done
428 All machine work is done.
Needs assembled. Still at machine shop should be done soon. Comp cam hydraulic flat tappet. Xe284H-10 Int. Ex. Lift 507-510 Dur 284-296 |
Is the converter the 20230 or the 20235?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
Coan converter
coa-20320-2 New cost $1075. |
Can you take a pic of the PN?
Pictures of converter part numbers.
The previous part numbers I posted are the part numbers that Coan supplied me a few days ago when I called them about this converter. |
428 Short block is sold
Hi, Do you have the measurements for the rear, outside flange to flange if possible? Where are you located in Ohio? Thanks, Shawn
67 GTO 455,Super T-10,Wenzler Ram 79 Trans Am 455 Pro Stick Racing 2005 Thunder Mountain Blackhawk 103" 2019 Street Glide 114" |
It's factory width.
I have it in my 70 GTO. Near Lima Ohio |
Is the converter standard space or for a mid plate.
Standard
PM Sent. Thanks, Shawn
Thread Tools | |
Display Modes | |
