Old 02-01-2023, 03:27 PM
Default Spark Plug Wires
Who has correct length spark plug wires? I don't want to cut and make them. I've bought the ones off of the larger sites, but it seems like they're too long or too short. I also have an HEI distributor so I'm not sure how that affects them. I'm also getting the wire loom brackets from our host for a '67.
Old 02-01-2023, 03:40 PM
77 TRASHCAN's Avatar
Well...I'd try to find someone that sells AC Delco brand parts. Not a lot of retail distributors carry the line, but AC wires may fit better.
I guess you are going with a points distributor, or some sort of small cap distributor that uses stock type wires?
Shut it off
Shut it off
Old 02-01-2023, 03:58 PM
That's a tall order if you want them to fit correctly in factory style wire holders.
They also generally don't come with the correct straight boots for the cap. Nothing that I've seen anyway.
As much as you may not want to do it, the best route is making your own so each wire can fit exactly as it should. I usually go the extra mile and buy straight terminals and straight boots for the cap end of the wires from Napa so I can make it all appear as it's supposed to.
https://youtu.be/XqEydRRRwqE
Old 02-01-2023, 04:07 PM
ZeGermanHam's Avatar
Just curious, why do you not want to cut them to length on your own? It's a very simple and easy process that ensures you get a perfect fit. Not hard to do at all.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 02-01-2023, 04:30 PM
I guess if that’s my only option, then I’ll look at cutting and crimping. I was hoping that someone had a set tailored for our engines.
Old 02-01-2023, 04:33 PM
With the wire brackets changing from model to model, AC and non AC etc.....It's about impossible for a manufacture to make and sell a wire set to fit everything out there and fit it "perfectly"
Old 02-01-2023, 06:17 PM
OK, thanks for the advice. So who makes a stock looking set that I can use with the factory wire loom? I believe that they have to be 7mm to fit the factory bracket and loom.
Old 02-01-2023, 06:30 PM
If you are still using a stock style distributor cap, what ever a parts store has on hand (or available. Not likely on hand for a v 67 anything. Ask about return policy in case the fit is WAY off). Go from there.
If you plan to use a factory style HEI distributor, 1975-1978 Pontiac 400 wires should work, regardless of body style.
Shut it off
Shut it off
Old 02-01-2023, 07:00 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
After about 10 years of service one of my DUI livewires broke when checking my plugs.
Picked up the premium HEI set made by Belden at Napa for a 78 trans am.
Cost was reasonable at 43.00. And honestly saw no fault with fit or performance so
There they stay.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
Old 02-01-2023, 07:01 PM
jhein's Avatar
jhein jhein is offline
I'll bet you a dollar that if you make your own you won't regret it. Easy and comes out perfect. I tried a couple different sets pre-made until I gave in and made them.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 02-02-2023, 12:34 PM
Kenth's Avatar
Kenth Kenth is offline
https://www.rockauto.com/en/moreinfo...t=7224&jsn=410
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-02-2023, 01:22 PM
Schurkey Schurkey is online now
Spark plug wire sets are...weird.
"Custom-fit" sets have all the wires too damn long, so they're a crappy "fit" on dozens or hundreds of applications.
"Universal-fit" sets are cut-to-fit by the customer, so they fit perfectly on that one specific vehicle.
I've given up on "custom fit" plug wire sets. I always cut to suit, and crimp on the distributor-end terminals and boots when I'm not making the entire plug wire from scratch.
Given a choice, I prefer the helical-wound (sometimes incorrectly advertised as "spiral") plug wires having a fine-metal-wire core. They tend to have longer service life than carbon-rope core plug wires.
Don't pay any attention to the advertising that brags-up the "low resistance". They're deceiving you by NOT telling you about the HIGH INDUCTANCE. Resistance, or inductance--either one--kills spark current while not affecting spark voltage.
Old 02-02-2023, 07:38 PM
PDC PDC is offline
I found the Taylor Thundervolt BBC HEI set fits a Pontiac engine very nicely with just enough slack to loom them up and over the valve covers. The 10mm set is cool if you like the aftermarket look, and they make the same set in black 8mm which fits factory plug wire looms. Get a black ‘stealth’ cap HEI from Davis Unified and it all hides in plain sight.
The Following 3 Users Say Thank You to PDC For This Useful Post:
Old 02-03-2023, 08:21 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
There they stay.
Gerry
I’ve also used these from NAPA, P/N 700255. Good quality and lifetime warranty.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
The Following User Says Thank You to Holeshot71 For This Useful Post:
Old 02-03-2023, 01:03 PM
vertigto's Avatar
vertigto vertigto is offline
Same here...worked out well on my 70 GTO.
