Old 01-29-2023, 12:04 AM
Jromaine87 Jromaine87 is offline
Default My 66 ready to go!
Here is some engine porn Click image for larger version
The Following 4 Users Say Thank You to Jromaine87 For This Useful Post:
Old 01-29-2023, 12:07 AM
Very Nice!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-29-2023, 12:17 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Bad Azz!!!
Go fast, see Elvis!
Old 01-29-2023, 10:54 AM
That's a very nice piece sir
Old 01-29-2023, 11:18 AM
shaker455's Avatar
Slick Machine!
Servicing the Pontiac community over 20 years
Old 01-29-2023, 12:08 PM
Richie Hoffman's Avatar
Very nice
2008KRE Q16 Winner
Old 01-29-2023, 03:38 PM
Dragncar Dragncar is offline
That is a nice piece of Pontiac. Can you tell us more about the car ? 4 link, what kind of rear and gears ect.
How much does it weigh.
Its going to lay down some good numbers for sure. looks fast just sitting there.
Old 01-29-2023, 04:47 PM
Originally Posted by Richie Hoffman View Post
Very nice
Thanks for the crank.
Old 01-29-2023, 08:02 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Now that's real nice !!
Old 01-30-2023, 08:52 AM
It’s a 1966 GTO Tube chassis
Weighs 2800 with me in it with aluminum block
535 made 887 at 7000 RPM( 905) with correct vaccum
4.56 rear gears and a TH400 with 2.48,first
60 ft is 1.28ish
Should do 8.70 in good air.
Car used to be owned by my uncle known on PY as greaserdegreaser
The Following User Says Thank You to Jromaine87 For This Useful Post:
Old 01-30-2023, 09:06 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Beautiful car and really cool it was your Uncle's
Chris D
The Following User Says Thank You to OCMDGTO For This Useful Post:
Old 01-30-2023, 10:02 AM
Gary H's Avatar
Gary H Gary H is offline
I love the look and finish on your car! Just curious on what tire size you have on it. With a 4:56 gear you may be turning A LOT of rpm's at the big end especially if you think it's going to run 8.70's. That would be in the 155ish MPH range.
The Following User Says Thank You to Gary H For This Useful Post:
Old 01-31-2023, 01:30 AM
32 inch tall tire. I was spinning around 7400 threw the traps at 145ish before.
Old 01-31-2023, 08:50 AM
slowbird's Avatar
slowbird slowbird is offline
You might want to think about 4.33 or 4.11 gears
The Following User Says Thank You to slowbird For This Useful Post:
Old 01-31-2023, 06:32 PM
Rusty4cyl's Avatar
Rusty4cyl Rusty4cyl is offline
Very nice
Blown 4cyl's to the front
Old 01-31-2023, 07:15 PM
Gary H's Avatar
I run a 33" tall tire and 4:33 gears. At 154 MPH I'm at around 7700 RPM's. Partially depends on how tight your convertor is. I don't think a little less gear will hurt you as light as your car is.
Old 02-07-2023, 07:24 AM
I ran a 9.27 at 147 this weekend, only got to make one pass as I found something in my oil filter I didn’t like, it turned out to be just debris from when I had my valley pan and oil filter resealed after the dyno session.
I definitely need some work on the chassis, with a lot more torque and Hp this go round I was bouncing off the line, just wasn’t a pretty launch.
Old 02-07-2023, 09:36 AM
PAUL K's Avatar
Nice job! When is your race with the Firebird guy?
Go fast, see Elvis!
Old 02-07-2023, 10:50 AM
lakefect lakefect is offline
[QUOTE=Jromaine87;6406479]I ran a 9.27 at 147 this weekend, only got to make one pass as I found something in my oil filter I didn’t like, it turned out to be just debris from when I had my valley pan and oil filter resealed after the dyno session.
I definitely need some work on the chassis, with a lot more torque and Hp this go round I was bouncing off the line, just wasn’t a pretty launch. [IMG]https://uploads.tapatalk-cdn.com/20230207/8148a4677a396ca68f647d483c24fd57.jpg[/
i would put 4.11 in that thing,thats a high starting line ratio
Old 02-07-2023, 12:00 PM
bluegoat65 bluegoat65 is offline
[QUOTE=lakefect;6406518]
I agree. I like a Glide with a 1.8 first and a 4.33 out back. I bet it nearly came off the ground on the hit with that 2.48 first ...lol.
