Old 12-22-2021, 04:52 PM
SRR's Avatar
SRR SRR is offline
Default What is this?
Found this while cleaning the garage.
ID:	580377   Click image for larger version
ID:	580378   Click image for larger version
ID:	580379   Click image for larger version
― Calvin Coolidge
Old 12-22-2021, 04:54 PM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
Looks like a big heat sink for charging a battery? someone here will know for sure
Old 12-22-2021, 05:20 PM
dataway's Avatar
dataway dataway is offline
I think it's a Solid State Battery Protector.
That's the limit of my helpfulness
Old 12-22-2021, 05:37 PM
OG68 OG68 is offline
Possibly a one way charging module for a secondary battery. Allows the second battery to charge but not discharge the primary(starting) battery when a load is applied.
2007 Cadillac SRX
Old 12-22-2021, 05:44 PM
Found this after a quick search
2007 Cadillac SRX
Old 12-22-2021, 05:58 PM
einstein's Avatar
einstein einstein is offline
It's an RV charging system splitter. You need to isolate the "car" battery from the "house" battery when charging them by the alternator while driving the RV.
Typically the house battery also gets charged by a charger that runs off 110VAC, either plugged into the campsite power or when running the generator.
Side note, that requires an ATS, or automatic transfer switch. You'd need the same type of switch for your home if you hard-wire a whole-house generator so the guys working on the power lines during an outage don't get electrocuted from backfeed power from your house.
The Following User Says Thank You to einstein For This Useful Post:
Old 12-22-2021, 07:17 PM
burd's Avatar
burd burd is offline
Alum scrap
Just Say No To 8” Flakes
F ire B irds
Old 12-22-2021, 07:22 PM
dataway's Avatar
Hehehe ... that made me laugh.
stellar stellar is offline
battery isolater. used to charge 2 batteries and if one goes dead from use without the machine running the other battery stays charged to start the machine. Often used on boats limos and cars running stereo without the car running
The Following User Says Thank You to stellar For This Useful Post:
Old 12-22-2021, 08:31 PM
VCho455's Avatar
VCho455 VCho455 is offline
Also commonly found in pickups with dual batteries and tow vehicles with batteries in the trailer that are charged by the truck. They were factory options as far back as the late 1960's on GM's and other manufacturers.
Allowed you to run the lights in your camper all night and still be able to start the engine in the morning
Old 12-22-2021, 10:08 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
I thought it was a McGanzer Flange but dataway would've recognized that.
Guess it's that charging circuit isolator module thingy...
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
The Following User Says Thank You to 4zpeed For This Useful Post:
Old 12-22-2021, 10:36 PM
einstein's Avatar
These are true. Also, dissimilar batteries need to be isolated as well, they will discharge if joined.
Old 12-22-2021, 10:43 PM
Stuart's Avatar
Stuart Stuart is offline
Typically, no. The isolator does just what it's called, it isolates the second battery from the rest of the vehicle's original electrical system Here's a typical schematic, there are a number of them online (just search for 'RV battery isolator wiring diagram'.)
The Following 2 Users Say Thank You to Stuart For This Useful Post:
Old 12-23-2021, 12:48 AM
dataway's Avatar
Frank
Thank you sir ... I was "This Close" to identifying it as a McGanzer Flange
Actually my 2011 GMC has one built in, cables hanging by a spare battery tray just waiting for the battery I never installed.
Old 12-23-2021, 03:51 AM
lust4speed's Avatar
While it looks sophisticated, it is still a couple of diodes with a big heat sink. I had problems with them and prefer a simple large solenoid switching the RV battery in line when when the ignition switch is on (and isolating the two when ignition is off). Maybe it was just luck of the draw, but I had two isolators where the diodes didn't switch off and drained the vehicle battery. The local RV repair said they replace them with the old reliable solenoid when the isolators go bad. Might be why this one is in your garage instead of installed.
Mick Batson
Old 12-23-2021, 05:29 AM
dataway's Avatar
I think it's missing a McGanzer Flange, would probably work great if it had one.
Old 12-23-2021, 08:21 AM
I also prefered to install the solenoid system. I found it to be more reliable, smaller, and easier on the charging system. The isolator will lower the voltage from the alternator connection to the two battery connections by 1/2 to 1 volt. If anyone is thinking about using the solenoid system, be sure to use a solenoid that is made for continous duty. Start solenoids are limited duty and will fry if used for this application.
Old 12-23-2021, 10:01 AM
einstein's Avatar
the ATS is unrelated to the battery isolator. That's why I wrote "side note" as I was referring to the 110 volt AC circuitry.
