Dash Rattle - Gauge Lenses
Hello,
'65 GTO I have a bad dash rattle. If I put my finger on the tach or speedometer lenses the rattle stops. There's slop there and it vibrates / rattles against the cluster or dash. Before I get under the dash, I wanted to see if anyone here had any tips. Maybe the gauge pods just need to be tightened up? Thanks
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
I've noticed that the factory applied black strip-caulk on the surface of the lens. When the instrument cluster is tightened to the plastic, it takes up the slack.
Lens: Anti-rattle bumpers
GM used 2 separate means to isolate the lens and keep it from rattling or creaking when the outside temperature changes.
First are 2 strips of "tar" as shown in the photos above. In behind the bezel you can actually see there are 2 raised ridges molded into the plastic which is the area where those tar strips nest. And second: there are 2 pieces of 1/4" long cut vacuum hose. They attach into the back of the bezel. In-between circle opening #1 and #2 plus openings #2 and #3 there are a pair of un-threaded "posts" molded in. On top of each post it gets thinner and that is where the vacuum hose rests. When the 4 gauge attachment screws are tightened the front side of the lens presses up against both ends of the cut vacuum hose and that puts a very light amount of pressure up against the clear plastic. Mainly that is what keeps the lens from making noise.
Peter Serio Owner, Precision Pontiac Last edited by Peter Serio; 12-27-2021 at 04:24 PM. Reason: added photos |
And that is why I always read your posts, Mr. Serio. Thanks. Learn something every day.....
"Bill"! |
