#41
After having to respray a '65 tri-power engine after the new Duplicolor light blue turned out very green, I called around and found out that friends were using the VHT Pontiac light blue engine paint. As far as I can see, the VHT is a perfect match. I've been buying the cans from Amazon.
The Following 3 Users Say Thank You to lust4speed For This Useful Post: | ||
#42
Web-surfing today and bought a few cans of Plasti-kote 208 at NPD
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
#43
You likely found the last available PlastiKote 208. It’s too bad Rustoleum sold the PlastiKote division to Duplicolor. I’ve called Duplicolor to ask them to change the DE1610 & DE1515 Pontiac engine paint to match the PlastiKote 206 & 227 Their answer was—“We’ll try.”
#44
Update-
So before I purchased the paint, I spoke with the NPD rep and he confirmed via email the paint was Plastikote 208. It arrived today and it isn’t Plastikote- it’s a Seymour paint mixed to match the 208. The good news is it is a perfect match and should be a good lead for anyone wanting the PK 208. While this worked out Ok, it amazes me the NPD sales rep lied so easily. Here is a pic of a piece of metal I painted with the Seymore to compare with my valve cover which is the genuine PK 208.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project Last edited by grivera; 12-12-2022 at 10:06 PM. |
#45
The color looks pretty good in the photo. I guess I would question about Seymour paint? Pigments, durability, fade resistance, oil and gas resistance and so forth. I am not familiar with the Seymour brand. Is it a good quality?
#46
Seymour is good stuff. Been using it for years. It might even be better than the Plastikote. We need to find out if it's heat resistant though... Engine enamel is usually good to 500 degrees..
"I know just enough to keep me here, but not enough to get me out" Last edited by Cardo; 12-13-2022 at 10:24 AM. |
#47
Dumb bit of trivia: Seymour "invented" spray paint. First to put paint in an aerosol spray can. Very old brand. Looks good.
#48
And also see if there is any printing on the bottom of the can. aka - might could bypass NPD and get Seymour color more directly. fwiw. |
#49
Those cans like that are a "generic" can of bases to be mixed. It's a line that Seymour sells that I've seen available from several vendors. I have bought several interior colors that way. The selling vendor mixes the color and puts it into the can on an individual can basis.
"I know just enough to keep me here, but not enough to get me out" |
#50
I inquired on the type of paint used and received this reply: “I confirmed with our research department, our AP-62208N is formulated as high heat engine paint. Being an engine paint it will be oil and fuel resistant.”
#51
So what paint available now has the best match for the 1965 and older engines?
Bill Strobel Owner Independent Towing 1965 GTO Nightwatch Blue/Aqua 2005 GTO Quick Silver/Red Fayetteville, NC Do It Right or Don't Do It All |
#52
Well for many Plastikote 208 was the go-to “correct” OTC paint and this mix by NPD/Seymour seems to be the same color as the PK 208 (see match in post 44)
#54
Good to know and thanks for checking. I'll have to order myself a few.
#55
The Duplicolor is darker than the 208: I have both.
I will use the Duplicolor on my 5.3 crate motor and selling 1-1/2 cans of 208. |
#56
I've had the same code number same brand of Pontiac blues come out totally different!
#57
It is pretty light:
