Old 09-23-2005, 10:20 PM
lovedemnewfies's Avatar
lovedemnewfies lovedemnewfies is offline
Default Transmission Help
Hi All, I have a problem with a new TCI street fighter trans, and/or TCI converter. Problem is is that after engine start, I can drive it for approx, 1/2 mile, then loose all gears. In order to get the car moving again, I have to shut it off for a 1 min, then restart, and it works. Its reall annoying cuz sometimes it happens in traffic. I've checked the fluid level, and its a bit above the required mark, I also looked at the converter bolts to flexplate and all are tight. From the Factory it said it put out the right pressure. Any ideas
Old 09-23-2005, 10:38 PM
theoldone theoldone is offline
On Vacation
wow- sounds like you are losing pressure to the clutch packs somehow and it's not holding the gears- like you have a bad front pump in that trans or something. perhaps they muffed one of the o-rings when installing it, or ??
pull the trans, take it to a trans shop, have them go through it
Old 09-23-2005, 10:41 PM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
Stupid question but did you check you fluid level ??? I had a friend with a similar problem. He filled it to wht he thought was full. But after he drove it it stopped moving. He discovered it was actually half full. Give it a check. Can't hurt.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
