1968-72 GTO vs. 1970-81 Pontiac round port headers
greetings...would like to get opinions on ROUND PORT header fitment.
for 40 years I've been under the impression, headers that fit 1968-72 GTO, also fit 1970-81 Firebird. but that was D-port headers. I'd like to put RA IV heads on my 70 GTO 455 engine. My question is the same as above statment: does a 1970 Firebird round port header, also fit a 1970 GTO ? because...lately I'm seeing different part numbers for GTO and Firebird, same year 1970. what's up with that ? these headers are PRICEY now, even used, so I don't want to buy a header, only to find out it doesn't fit. all opinions welcome, thanks. |
Different rounds port headers for A body and F body for sure. I had a Hedman set of 1 3/4 that were supposed to fit early A bodies and second gens-both sides rear tubes hit my TAs firewall!
70 TA I know Hooker 4202s will fit good. Some will need "clearancing" around the oil filter or lower A Arm pickup.
I have an A-body 70 GTO, thinking of running RA4 heads, and there seems to be quite a few pair of used Firebird 70-81 round port headers around for sale. I was going to try the 70-81 Firebird headers on the 70 GTO specifically, not the other way around. any idea if that would work ?
No idea but the cheaper stainless OBX GTO round ports do not fit a second gen. Might be able to fit changing a couple of tubes. If the OBX are still around they might fit.
what does OBX stand for ?
That is the brand. They were cheap 2-300 stainless steel round port headers for 68-72 A bodies. Used to be on Ebay all the time.
http://www.obxracingsports.com/products.php?pk=1838
