You can just polish the retainer with some 600/800 paper, it should be fine.
Update.
The clutch forks should be hardened steel. The repop clutch fork I used was not. A stock or common aftermarket pressure plate requires 300 lbs. to move the pressure plate diaphragm. My Center-Force requires 350-375, so more stress on the unhardened clutch fork. I should receive my OEM clutch fork on Monday, and I purchased a new pressure plate and clutch from the specialty clutch shop, which I installed today. I am happy to have discovered this shop, they assemble / rebuild clutches, pressure plates, grind flywheels, and have all sorts of tools and machines for testing and servicing these things. The staff is very knowledgeable about all things clutch related.
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
Hm. So they are saying it was because the fork wasn't hardened? Not sure I buy that, or it would have bent on both sides.
Guess we will find out after some use. .
Yeah, that is a working theory, and it is loosely supported by facts, but who knows for sure. Facts:
1) There was no damage on any other component other than the tranny front bearing retainer. 2) The clutch fork steel is not hardened. It should be. 3) My pressure plate diaphragm does require 15-25% more pressure to actuate, thus putting more stress on the clutch fork. We tested it on the machine. Other tid bits of info from the clutch. The flat head pivot ball, that I didn't like as it doesn't cleanly fit the round recess in the clutch fork, they said it is that way for a reason. It traps / retains a nugget of grease. If they were a round, mated pair, it would push out the grease. They don't like Center-Force. The PP weights are a gimmick that only work at really high RPMs (6k+). They had other comments as well. They assemble most clutches from blanks there based on ones car and goals.
Thread Tools | |
Display Modes | |
