Old 01-10-2022, 11:28 PM
takid455 takid455 is offline
Send a message via AIM to takid455
Default why the change from 4.21 vs 4.25 stroke
This has questioned me & I never got a solid answer?
Is it a manufacturing thing?
Old 01-10-2022, 11:38 PM
tom s tom s is offline
Cheaper rods.Tom
Old 01-10-2022, 11:45 PM
LT4USMC LT4USMC is offline
Plus you can use longer rods and lighter pistons
Sent from my SM-G988U1 using Tapatalk
Old 01-10-2022, 11:55 PM
FrankieT/A's Avatar
I have never seen the point unless you need an entire rotating assembly anyway. If I needed crank rods and pistons I would do it. To gain 4 cubic inches?
Old 01-11-2022, 12:47 AM
firechicken's Avatar
firechicken firechicken is offline
I wonder why Pontiac chose a 4.21 stroke in the first place? Any thoughts?
Old 01-11-2022, 01:28 AM
Dragncar Dragncar is offline
The 4.25 stroke thing started out at Butler. You can offset grind a stock 455 crank .040 and down to BBC rod size. Butler was the first to do this with off the self 6.8 BBC rods. At least he told me he was the first guy to do it.
Then you have Butler with their deal at ROSS pistons, they are the ones who got us our own forgings, not a other brand adapted to a Pontiac. They have more off the self Pontiac pistons than anybody. And they sell more Pontiac E heads. Have had a relationship with Vic Edelbrock(RIP) for years.
So the answer is, Jim Butler.
Also, there was the era when you could not get any steel Pontiac aftermarket forgings. Thats why H-O Racing went with the BME aluminum on the street deal.
So off the shelf Chevy rod combos were a fix for a need. AND, longer rods used to be a thing when all we had was iron heads. Once you fully port a RAIV or D port head stuffing a longer rod got a tiny bit more power. But once we got aftermarket heads the point was moot.
Old 01-11-2022, 01:29 AM
Well, to get 455 ci.
Chevy had their 454. And Olds, Buick and Pontiac went with 455.
Numbers game.
Old 01-11-2022, 03:09 AM
Gach's Avatar
Gach Gach is offline
This is how it started out, back in the 60’s we had no steel rods, well we kid of did, the early 62 steel rods, but the were called rubber rods. They weren’t very good rods. Maxey and Nunzi were the frist to do this. Chevy steel rods were allot cheaper. We desperately needed a good steel rod. Seeing companies made Chevy steel rods by the thousands. It was determined by them, turning our cranks down .040 which make rod Journal size of BBC. 2.200. And pin size .9270 which was SBC size it was a not brainer, to get companies like say Crower to make us a good steel rod, wasn’t going to be cheap.
Crank Shaft specialist was the main crank company in that era. They were the best, really really good crank grinders. They said why not off set grind the crank and make it 4.250 stroke. Now we had allot cheaper basically a Chevy rod. Allot cheaper then having to go with a whole new mold. So to speak for out Pontiac’s. Which would end up costing allot more money then a Chevy steel rod.
Besides that the early 62 steel rods were only available to the Pontiac NASCAR races. Very hard to get. Later when Butler came along they copyed and went to a 9900 pin. So guess what we were no longer limited to 5500 rpms with the stock cast rods. It open the door to make hp.
The Following User Says Thank You to Gach For This Useful Post:
Old 01-11-2022, 03:18 AM
Gach's Avatar
Once the companies saw their was a market for Pontiac you could get stock Pontiac rod Journal size. Steel rod. Thats kid of how the 4.250 stroke cam into play.
Old 01-11-2022, 03:48 AM
It was very hard to get a good Pontiac rod in the 80s, when my 455 was going together. I found 6 of the early SD 421 rods, but could not find the other 2.
So I paid 800$ for 8 new SD 455 rods and had them shot peened and re sized. Had 1200$ into them, the cost of Crower billets at the time.
It was kind of a mess. I mean, you had to try real hard to be a true Pontiac guy with hardly any decent rods to buy.
The Following 2 Users Say Thank You to Dragncar For This Useful Post:
Old 01-11-2022, 07:21 AM
The reason Pontiac produced the 421 cid motor was to not only keep up with the Jones so to speak, but surpass them!
Chevy had the 409 and Chrysler had the 413 and Ford had the 406.
Old 01-11-2022, 10:31 AM
Numbers game.
All 3 of those engines have different stroke Chevrolet and Buick chose less stroke and bigger bore. I know it’s all we have but a 4.211 limit or so for a 455 block stinks a Buick stock bore is 4.3.
Old 01-11-2022, 10:57 AM
Just always thought it strange they went from 3.75 to 4.00 but then 4.21. Why not 4.25 from the factory?
Old 01-11-2022, 11:17 AM
Steve C. Steve C. is offline
Not a specific answer, but two interesting related article....
https://www.drivingline.com/articles...ast-big-block/
https://www.liveabout.com/gm-455-cub...ig-bloc-726346
Old information here:
Old 01-11-2022, 11:28 AM
Stan Weiss's Avatar
My understand is there was a ci limit from GM. Pontiac could have gone 4.25" stroke and a 4.13" bore and came up with the same ci. But they wanted the extra bore.
Stan
Pontiac Pump Gas List
Old 01-11-2022, 12:26 PM
Related to that, I'll take a wild guess as to why the specific stroke.
It was simply for marketing reasons, they wanted the number "455". When they increased the bore size to 4.151 the GM engineers determined that was about the maximum the venerable Pontiac V-8 design could go for longevity in service. And with that bore size a crank with 4.210 stroke gave them their desired 455 cubic inches.
From the article above and relating to the marketing reason...
"Over time, it would gradually push displacement higher and higher until it stood alongside its corporate stable mates in terms of overall size, without necessarily adopting the 'big block' name."
Old 01-11-2022, 12:33 PM
Figured it was something along the above.
Not to derail the thread too much, given the choice, would you run a 4.21 crank & have it offset ground to deck the pistons with 73/4 SD rods or 4.25 w/ new rods? SD Rods are acquired as with SRP forged pistons. Crank is needed. Application/ purpose - fun street. mid -upper 400hp
Old 01-11-2022, 12:38 PM
Longer rods decrease piston side load which really rears its head in the 427 (7.0) LS...
Old 01-11-2022, 12:54 PM
Not really. Longer rods increase the side loading on the major thrust surface of the cylinder bore.
Dr. Thomas Sowell
Old 01-11-2022, 01:15 PM
To mirror comments already made here involving Butler and Eagle Specialty Products.....
Recognizing the dwindling supply of affordable 455 crankshafts, Loftis states, "We crossed over into the Pontiac crankshaft market around 2000 when we teamed with Butler Performance to develop a cast replacement. At the time, original 400ci crankshafts were plentiful, so there wasn't much need for a 3.75-inch stroke unit. We found that hobbyists wanted maximum displacement, so we introduced a 4.25-inch stroke unit for the 400 block, and other products followed."
Source:
https://www.motortrend.com/how-to/hp...kit-schooling/
