Old 08-21-2022, 10:56 AM
70geeteeohh 70geeteeohh is offline
Default 1970-1972 Gto 2 different Dash vent sizes?
Hoping someone could shed a little light on this subject. I am reading that there are two different size dash vent bezels offered for these cars.
A "wide base" and a "narrow base" bezel.
Since I am completely lost on this can anyone explain to me the TECHNICAL difference between the two and how to tell which vents I need to order for my 1970 GTO?
My car had a Tempest Dash installed by the previous owner. (Don't ask!)
I since removed it and bought a nice driver quality GTO dash to replace it with. Unfortunately it got the bare dash with no vents or bezels. So I have nothing to compare it to.
Pictures would be great if anyone has them to compare the 2 different size bezels.
Old 08-21-2022, 11:32 AM
Where did you read this?
Old 08-21-2022, 11:39 AM
Both OPG and THEPARTSPPLACE have listings for wide and narrow vents.
Old 08-21-2022, 12:32 PM
Can't remember running across the wide & narrow outer vent frame deal. Have before sent pairs of outer vent frames off to be restored /revaccum metalized & painted but they always were out of the same original dash. Need to pay better attention as I strip several remaining dashes down to cores. Am networking to get several dash cores to El Paso.
Old 08-21-2022, 12:35 PM
I believe the vent bezel sizes different from L to R. Either will work from what I read. So some cars might have 2 narrow bezels.....while others have 2 wide bezels or a mix of both.
I guess until they are side by side 95% of us would never notice.
Old 08-21-2022, 12:46 PM
I'll take a look this afternoon at a '72 dash asm I have out of a 4200 mile Lux LeMans.
Old 08-21-2022, 02:57 PM
DavesGTO's Avatar
DavesGTO DavesGTO is online now
I bought mine from our sponsor, no problems. Ames does list 2 different part numbers for 70 - 72 left and right which is what i ordered.
The Following User Says Thank You to DavesGTO For This Useful Post:
Old 08-21-2022, 03:07 PM
TxSportCoupe's Avatar
TxSportCoupe TxSportCoupe is offline
Wish I still had mine out so I could show you. I ordered one of each. One base (vent frame) is slightly wider than the other. Something you really wouldn’t even notice unless you’re an engineer or really technical. I read that material saying which year had which one and which side went where and, the disclaimer that factory cars all over the country had every mix of bases imaginable. And, you can’t tell which is which, once installed. Unless you previously measured and marked your setback. The difference is “Nominal”. And if I someone sneaked over and swapped mine side to side, I’d likely never know it. As I understand it there are no hard rules on this item. Too many real dragons to slay. Step around this one.
Old 08-21-2022, 03:29 PM
Very good answer. Than you. Didn't want to place an order and get the wrong one.
Old 08-21-2022, 06:01 PM
Old 08-21-2022, 06:06 PM
I was looking at some catalogs and AMES says the one side is taller than the other. That's the difference?
Old 08-22-2022, 10:52 AM
kk68's Avatar
kk68 kk68 is offline
Funny that this thread popped up….I just pulled my 71 dash yesterday and also noticed the differences between the left and right vent bezels. Here’s some pics of left and right vents. Left side bezel is 1/4” taller than right. Width is the same, top and bottom clip design is different. Part no. 9782505 only on smaller right side bezel. The vent mechanisms that clip into the bezels appear to be the same for both sides.
ID:	596978   Click image for larger version
ID:	596979   Click image for larger version
ID:	596980   Click image for larger version
ID:	596981   Click image for larger version
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
