Old 08-06-2021, 07:22 AM
steve25 steve25 is offline
With whatever head you run you should do some cylinder Bore Intake valve chamfer work.
Here's a picture of a iron head that started life with a 1.96" valve and then fitted with a 2.02" valve .
The wood in the first picture represents a 350 Bore at .030" over, the second picture is shows the chemfer that's needed to get that 2.02" valve unshrouded a good amount.
ID:	570878   Click image for larger version
Old 08-06-2021, 08:10 AM
gtospieg gtospieg is offline
Steve25...Do you know how many cc's that chamfer added?
The Following User Says Thank You to gtospieg For This Useful Post:
Old 08-06-2021, 08:14 AM
deltarat deltarat is offline
while this is a good practice, it was the exhaust valves that made contact.
Old 08-06-2021, 08:23 AM
I have the CC s noted at home so I will have to check for you later, but if I had to guess right now I would say 3.
Your Exh valves kissed your pistions, not your cylinder wall is what you posted, no?
I don't see what that has to do with a Intake valve chamfer I gotta say!
Old 08-06-2021, 01:08 PM
in retrospect, i dont see how cylinder chamfer has to do with the exhaust valve hitting the slugs
its already ran with 2.11 intakes and i dont see any contact what so ever.
but while i needed to retort to your comment, i do agree with you
