Old 03-29-2003, 09:07 PM
Larry Navarro's Avatar
here's an interesting item I stumbled accross on EBAY.....should make for a lively topic.
I noticed that this melling pump #54F does NOT have the heavy cast bottom plate
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6770
1973 SD455 T/A
1979 S.E. T/A
http://community.webshots.com/album/16587603rOyvmFCiHs
1973 SD455 T/A
1979 S.E. T/A
Old 03-29-2003, 09:16 PM
Will Will is offline
Larry,
I just received an M54DS pump, which also doesn't have the cast bottom plate. I know this isn't an SD pump, but I thought it was still supposed to have the heavy plate.
Looks like I'll be buying Speed Pro pumps from now on.
'72 Formula 400
12.77 @ 108 / 234/244 cam / Q-jet / 3840# / 3.23s / street tires (not DRs)
'73 Firebird 400/4-speed
Old 03-29-2003, 09:28 PM
I run quite a few of the Melling M54DS pumps on my cars, all of them have the same non-cast bottom plate as seen in that eBay auction. All of them work just great, I clean and prep my own pumps. Stock pumps have an almost paper-thin bottom plate, the one on the Melling pump is stout enough I would think.
Seems funny how that $29 pump in the eBay ad costs $75, it doesn't even include a pickup. I would think it should include a pickup, attached the way most performance users would like either by welding or running a fastener through the pickup tube and pump casting.
Old 03-29-2003, 10:11 PM
Goatman Goatman is offline
On Vacation
What's done to that pump is alot of labor intensive work. It takes time and that dude wants to get paid for every minute.
Better to pay $75 than get a stock $29 pump and take a chance? Its all up to the consumer.
Chance favors the prepared mind.
Old 03-30-2003, 09:31 AM
Lerry: The Body Ventura..'s Avatar
Lerry: The Body Ventura.. Lerry: The Body Ventura.. is offline
Send a message via Yahoo to Lerry: The Body Ventura..
The bottom plate looks like all the ones I've ever owned? I thought the one shown in the e-bay ad was the thicker plate?
Old 03-30-2003, 10:16 AM
Tom Vaught's Avatar
Boost Engineer
Considering what He is doing, I have now found my
pump guy!
I would easily pay $50.00 to have all of the prep done that he is advertising. Easily a couple of hours of labor plus the coatings, the polishing,
the safety wired bolts, etc. Thanks Bruce and Larry for the info. Tom V.
ps I have about 20 of the Wolverine Blue Racer
oil pumps I bought when they were a part of Camshaft Machine/ Crane. None have the older cast
bottom plates with the Phillips head screws, All are the medium thickness plates with bolts.
[This message was edited by Tom Vaught on March 30, 2003 at 12:25 PM.]
[This message was edited by Tom Vaught on March 30, 2003 at 12:27 PM.]
Old 03-30-2003, 01:17 PM
PONTIAC DUDE's Avatar
Well, I have been selling and using the DynaGear pump for quite awhile now and the workmanship and quality control seemed great. They had the thicker bottom plate. No trash internally and no rusted up check balls. Just a better pump all the way around.
Now the bummer.
The DynaGear Company went under and Melling bought the Pump division.
Tried to buy all the pumps available anywhere, but they are no longer shipping pumps from DynaGear. Why I don't know.
Now I'm running out of options for a quality pump at a "Fair" price.
Build it fast, build it right, build a Pontiac.
http://PontiacDude.cc
Old 03-30-2003, 01:37 PM
On Vacation
Looks like we all need to start e-mailing BOP Engineering asking when their new oil pump will be done!
Old 04-02-2003, 06:16 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The last two Mellings I have gotten have the stamped steel plate. Speed Pros have the thicker cast plate.
Skip Fix
Old 04-02-2003, 06:48 AM
critter's Avatar
critter critter is offline
So, is there any reason not to swap a thicker bottom plate from an older pump onto your new pump, provided everything matches up and fits?
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 04-02-2003, 07:08 AM
On Vacation
I am confused as to why you would need the thicker plate if everything matches up and fits to begin with. Nothing is supposed to touch the plate as it is, so what difference does it make whether it is think or thin?
Old 04-02-2003, 05:13 PM
The thicker plate won't flex as much as a thin one and lose oil pressure due to leakage at the pump body to bottom plate interface . Even if the gears never touched or put thrust downward on the plate a thin one will flex and leak due to oil pressure alone. This is at least one reason why the factory would have added the thicker plate on higher pressure RA and SD oil pumps.
Let's go racing!
www.outlawpontiacs.com/members/B-Man2.php
www.outlawpontiacs.com/members/B-Man.php
