65 cc eheads. 11.5:1
Street strip on 110 octane.
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
I use R-5671A-7 on engine like you are describing
Thanks Paul
You are welcome Adam
That's what I'm currently running, the 8s were a tad too cold, it likes the hotter plug. Good luck.
R-5671A-7
I'm running R5671A-7's also. Be aware that when you go to buy them at a parts store they may not be listed that way. For some reason some stores, NAPA, O' Reily's, Summit, lists them by stock number. I think the number is 4621.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
I use 5672-A8's. Used same plugs on both gas and alky.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
i used those on the 467 with the alky rick. I have some left over. may try both and see what it likes.. Hoping to get it on the pump and broke in soon.. then i can start saving for a decent bottom end to park under it.
