HEI ignition wiring on 73 TA
I am re-assembling my 73 TA and have some questions on ignition wiring. I am upgrading to Dave's Smallbody HEI, which requires a bypass of the coil resistor circuit. Where can I wire in a direct ignition wire to the coil? The fuse panel doesn't show a ignition connection. How do I find the ignition connection? (Electrical issues are NOT my strong suit)
Secondly, there is a brown and pink wire comming off the tachometer circuit board. The brown wire has an inline fuse and appears to go to the coil. Is this a positive or negative connection? I apologize for the dumb questions. I was not the one who disassembled the car so don't have notes or pictures of what went where.
BrockB 1973 Trans Am |
Your fuse panel should have a cavity that is ignition hot you can run a nice 10 gauge wire to the HEI.
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. |
The brown tach wire goes to the coil negative. You can jump the IGN1 and IGN2 circuits together under the dash, that'll bypass the resistor wire, or you can attach a plain stranded wire to the IGN1 circuit on the engine side of the firewall bulkhead connector where the wire comes out of the connector.
If you don't have a wiring diagram we can provide one. George
