72 trunk app
For those of you with 72 vehicles...... how far above the trunk lower edge is the bottom of the PONTIAC emblem? Car has no existing trunk mounting holes.
Drew Fifteen hundred years ago everybody knew the Earth was the center of the universe. Five hundred years ago, everybody knew the Earth was flat, and fifteen minutes ago, you knew that humans were alone on this planet. Imagine what you'll know tomorrow. - K (from MIB) 1972 LeMans Sport convert (T41) '70 XF 455, TH400, 3.31 12-bolt Posi |
pretty sure it's a 1/2"
better resolution pics on this link https://www.primoclassicsllc.com/197...mans-c-293.htm |
Here you go. Looks to be 5/8". I also sent you a PM awhile ago asking about a seat belt. Did you get that?
Jeff |
Assembly manual has exact measurements, can check there.
Call our host, they may be able to fax or email you a diagram. They are a wealth of info. .
Jeff, Sincere apologies for not responding. I do have a set of black rear belts. They are not ones I would use however. Currently attached to chassis so tight an impact gun won’t break them loose. Also very nasty. You’d better off getting a set from our host at APE.
