Automatic back drive linkage?
Anyone reproducing the back drive linkage for the 70 birds? Automatics I wouldn't think are that hard to come by. Not seeing them anywhere.
What are you looking for? There should be plenty of used pieces around, I know I have some from parting a car or two. I don't know if anyone is reproducing them though.
Chris
Like the sign says, "speed's just a question of money. How fast can you go? Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. Albert Einstein |
Thanks Chris,
Missing the entire reverse rod setup for a floor shift automatic, the pieces that connect to the column itself to activate the backup lights and ignition lock/lock floor shifter in place etc.... I believe there should be a bracket that mounts on the frame that also coincides with the shifter on the trans, then a rod that runs up to the steering column. For some reason I thought this was reproduced (looks alot like a column shifter setup) so I figured fairly common. Apparently I'm mistaken. Any help appreciated. Thanks Larry |
I'll take a look when I have some time. I know I have some manual parts not sure on the automatic stuff. Looks much simpler for the auto stuff.
Yes Chris, that would be it in the picture.
I am parting out a 74 if any of it will be the same .. P.M. Me if ......
PM sent
Thanks |
