Old 05-18-2003, 07:28 PM
Goathead's Avatar
Goathead Goathead is offline
Send a message via AIM to Goathead
Thinking of converting my Muncie M20 to a Turbo 400 with good converter for Southern Nationals. Question is, would you do it for a street/strip application, and what are the +'s and -"s?
http://www.dannys65gto.com
http://kurtspontiac.homestead.com/dannys65gto.html
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC]
http://www.youtube.com/watch?v=iJrDl3nRNCM
http://www.youtube.com/watch?v=Fvywdocl4GA
http://ultimategto.com/icongraf/65headtitle.jpg
Goathead's Avatar
Old 05-18-2003, 07:37 PM
Txbobcat Txbobcat is offline
u got mail.
Old 05-18-2003, 07:38 PM
What kinda HP/Ft Lbs. are you making?
I've always liked a 4 speed!
SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY.
I Misus Rash'!
Old 05-18-2003, 07:52 PM
Goathead's Avatar
Larry, engine dyno is 468 hp and 540 ft/lbs on 93 octane shell....
Old 05-18-2003, 09:42 PM
WDCreech's Avatar
WDCreech WDCreech is offline
Danny, If you want to have the most fun on the street, go with a four speed. If you want to run consistant at the track, go with an automatic!
Bill
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08
Old 05-19-2003, 03:43 AM
I believe w/ that amount of torque you'll have to use a manual valve body?
But I still like a 4 speed in a muscle car.
Now race only is a different story. Just get good at working those gears. Ask OMT.
I Misus Rash'!
Old 05-19-2003, 04:43 AM
Goatman Goatman is offline
On Vacation
If you like changing clutches and breaking ujoints/rear ends, go with the four speed. If you want to make passes, go with an automatic.
Causin' pain like two bad nurses.....
Old 05-20-2003, 05:43 PM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
The Th400 is a good choice if you are going racing.
4-speeds don't have the advantage they used to have.
If you go the Th 400 rout.
get the HD case used from 65-67 on the Pontiacs
Then use the best of internals and clutches from the 3/4 ton truck's. Use hardened Sprags and a stall converter that matches your engine.
Usually I'm found working on my Pontiac. If you want to find me Look for the white picket fence and all the old Pontiacs parked outside. And the half dissembled engine sprawled all over the driveway!
Try calling CRUSHPROOF! 512-386-9889
