Throttle cable
I'm installing a 76 Q-jet on my 73 bird. The newer carb has the stud with clip attachment for the throttle cable. The car has the ball and socket type. Can i simply install a throttle cable from a newer F body, or cut the stud off and use the ball style off the old carb. Looks like the latter will have a clearance issue with the secondary link rod. Thanks.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
Probably simplest to install a 75-78 4bbl. T/A throttle cable...
If your 73 is originally a 4bbl & the cable is not broken,don't brake it...I could use one...
Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
Just check out the hole in the firewall. When I tried the conversion of a 78 cable to my 70, the square was different. I went with Mr. Gasket cable. The braided steel slips off to reflect stock look if it is a concern.
2-1962 Lemans convertibles 4cyl, auto 1962 Tempest safari wagon (running project) 1972 455 Formula (tribute) 1962 Skylark convertible 215 4-barrel , auto 2009 G8 Sport red metallic, Onyx leather Whatever else that make my way into the driveway |
I just dressed the sides of the plastic insert with a file & it fit real nice.....
Thanks for the reply's. 2many, i'll hold on to the old cable just in case. But I'll see your alice cooper and raise you a grand funk railroad.
http://www.youtube.com/watch?v=4foKsKB6wP4
Just received a new throttle cable by Pioneer Inc. Made in USA. Looks like it's going to be a seamless conversion.
Thanks for helping out the New Guy. B&P
Just wanted to add that The Parts Place, Inc. is now marketing the ball-type cable. Listed as 1971-4. I can't comment on the quality yet.
PY sells one marketed for those years too. I had them measure it and it was not a fit for the 72/73 4bbl Birds. Just a heads up to anyone looking.
The pioneer cable housing was 3/4 inch longer than stock but i can live with it. I did trim the housing square where it enters the bulk head. It does open the Q-Jet to 100%
Another disappointing reality from the reproduction market. Thanks for the heads-up.
