Old 12-29-2013, 06:14 PM
400 plus's Avatar
400 plus 400 plus is offline
Default Found fost plug on floor
Must of got to cold in garage DUHHHH! Center drivers side on my new combo with new frost plugs brass 1 61/64ths. Can I just tap back in or get new???? Any thing else???
Old 12-29-2013, 06:20 PM
ponjohn's Avatar
ponjohn ponjohn is offline
dumb question...antifreeze in it?
Old 12-29-2013, 06:29 PM
400 plus's Avatar
NO No No
Old 12-29-2013, 06:37 PM
70pontiaction 70pontiaction is offline
Thumbs down OUCH!!!!!!! That'll definitely leave a mark.
I'd be thinking about teardown and magnaflux myself.........
I never lost a freeze plug (due to freezing) without FURTHER damage.
Probably NOT what you want to hear........my condolences........
Old 12-29-2013, 06:43 PM
jetallman's Avatar
jetallman jetallman is offline
How cold is it there, I haven't heated my garage yet and even in single digits outside nothing inside has even came close to freezing
69 455/4-sp windward blue under major restoration
69 400/400 waiting for resto
Old 12-29-2013, 06:55 PM
Sirrotica's Avatar
I had one push out of a 68 400 block and I was damn lucky, I just drove it back in and refilled the cooling system with no further leaks. As has been already said though, the chances of getting away with it just pushing the plug out, without cast iron cracking is remote. I've seen way more blocks crack from freezing than I've seen plugs push out without further damage.
KW ceramic block or Bars leaks block sealer will repair small cracks. Stitching with overlapping threaded plugs, or having it welded by a competent cast iron welder can save your block sometimes. If there is an external crack you really need to look at the valley inside too as they crack on both inside and outside sometimes.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 12-29-2013, 07:58 PM
PONTIAC DUDE's Avatar
Thumbs up
Get a new one a use a sealer around it. Tap it in. You can feel the pressure installing to determine if it fit's correctly.
The Following User Says Thank You to PONTIAC DUDE For This Useful Post:
Old 12-29-2013, 08:00 PM
400 plus's Avatar
Thank you
Old 12-29-2013, 10:10 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
I had the same thing happen. Saw a puddle and a plug. Put a new one in and it never gave me any trouble.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 12-29-2013, 10:46 PM
ponjohn's Avatar
If you don't run antifreeze, can you be drain all the water and be confident with it dry over the winter?
Old 12-29-2013, 10:56 PM
charlie66's Avatar
I had the same thing happen. I used the same freeze plug with copper sealer . It working fine. That was 2 years ago and its still fine. If you see no cracks. Put it back in and try it. If it doesn't leak then you should be good to go...
Good luck...
My Half AN Injun.....
Old 12-29-2013, 11:00 PM
400 plus's Avatar
I see NO CRACKS! I will reuse with RTV around frost plug. Gonna check the oil tomorrow. Pull plug and check
Old 12-30-2013, 03:36 AM
Schurkey Schurkey is offline
The LAST thing you want is RTV silicone.
Silicone in an aerosol can is a lubricant. You want a greasy core plug?
1. Installing a core plug distorts it. Don't re-use them.
2. Any non-silicone, non-Teflon gasket sealer will work fine. Copper Coat, Indian Head, High Tack, Gasgacinch, Permatex 1, 2, or 3, etc. On my engines, I use cheap epoxy such as JB Weld.
Old 12-30-2013, 03:44 AM
I use the black permatex , it's nasty but works great fro core plug. But if it poped out get a new one if you don't have any cracks in the block. I don't know anyone that didn't have a cracked block when a core plug came out from freezing. I hope you have better luck.
Old 12-30-2013, 04:09 AM
400 plus's Avatar
Ok Ill get a new one and use permatex. Wish parts stores were open at this time of a.m. LOL Maybe pickup a lottery ticket. Biggest thing first is to drop the oil plug and check for water.
Old 12-30-2013, 08:55 AM
Half-Inch Stud's Avatar
Originally Posted by PONTIAC DUDE View Post
Get a new one....
DITTO
Old 12-30-2013, 09:41 AM
ELKHORNAOG7 ELKHORNAOG7 is offline
Once you put the plug in I would let it sit a short time then I would fill it with water and do a pressure test on it (thru the rad) and see if the system holds pressure or not and if it does then I would drain the water and put antifreeze in it and run the engine if it holds pressure you can add a can of bars leak just for insurance and peace of mind-----BOB
Old 12-30-2013, 01:10 PM
400 plus's Avatar
OK I drained the oil pan??? NO WATER Put a new plug with KW copper sealer and fill with water no leaks yet. I will put pressure on the raidiator and check. Thanks guys. So far so good.
Old 12-30-2013, 01:57 PM
pugslyx234 pugslyx234 is offline
Wow. I dont like chances like that!
Old 12-31-2013, 10:01 PM
chrisinestes's Avatar
chrisinestes chrisinestes is offline
Well?
Enquiring minds want to know! And so do I!
Chris
Cum Catapultae Proscriptae Erunt Tum Soli Proscripti Catapultas Habebunt.
