Old 02-16-2024, 06:58 AM
steve25 steve25 is online now
If he did not think that you had enough installed height to run 740" lift then he must not have understood that your running a aftermarket head.
Old 02-16-2024, 09:06 AM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by Gach View Post
278/288 on a 110 with int 310/4485 lobe and exh 322/ 4455 lobe. $650.00 smackers…Its cracking me up.
Thought you had a special program that picked your cams?
Old 02-16-2024, 09:56 AM
Stan Weiss's Avatar
He wouldn’t really answer me, because I think he saw the controversy over the Comp cam 4470/4360 lobe.
Does anyone have a link to a comp cams master lobe list which has these lobes? The latest one I have doesn't have these lobe numbers.
Stan
Pontiac Pump Gas List
Old 02-16-2024, 10:49 AM
slowbird's Avatar
Stan
My master catalog doesn't show those lobes either.
Old 02-16-2024, 11:00 AM
Steve C. Steve C. is online now
The lobes Gach listed are from Bullet Cams Master list.
They are not UltraDyne lobes.
R310/4485 310 278 196 0.4485
R322/4455 322 288 205 0.4455
https://www.bulletcams.com/Masters/Rlobes.htm
Old information here:
Old 02-16-2024, 11:10 AM
slowbird's Avatar
Ok so those are Bullet lobes, so what is he talking about with this quote "controversy over the Comp cam 4470/4360 lobe"?
Old 02-16-2024, 11:13 AM
Stated.... "Comp cam 4470/4360 lobe"
I will suggest those are not lobe numbers. They are the amount of lobe lift.
Therefore Tim at Bullet would not recognized those as Comp 'lobe numbers' to compare specs.
Old 02-16-2024, 11:22 AM
Stan Weiss's Avatar
Steve,
If they are lift numbers then there would be a number of Comp lobe that fit each, also most people would have said .447/.436
Stan
Old 02-16-2024, 12:02 PM
Gach's Avatar
Gach Gach is offline
No really you figure that out, your amazing Steve.
Old 02-16-2024, 12:04 PM
Gach's Avatar
.[/QUOTE]
Steve,
Stan
Your a Genius I tell you. LOL
Old 02-16-2024, 12:05 PM
Jay S's Avatar
Jay S Jay S is offline
I think if you reset (loosen) the exhaust lash for the bigger rocker ratio, then tightening the intake lash, those together can change the valve timing event most than a 1.5* cam timing change. In the real world, changing the lash is probably quicker also.
Ever heard of a big SR spring good for more than .7” lift and coil bind less than 1”? Let me know when you find it.
Old 02-16-2024, 12:11 PM
Gach's Avatar
Oh god I can’t stop laughing and here I thought I was going to learn something.
Old 02-16-2024, 12:18 PM
Stan, you are correct. Comp lists the lobe lifts with three digits.
With that said, if one wants to wade thru all the Comp solid roller lobes listed here they can look for a .447 & .436
https://edelbrock-files-v1.s3-us-wes...be-Catalog.pdf
Side note: If one wants to nit pick.
If the Comp cam was ordered with a "B" suffix code then the lobe lift can, but not always, be altered slightly. But typically only increased by 0.001"
Old 02-16-2024, 12:29 PM
Stan Weiss's Avatar
Jay,
This is the cam I posted above with the 0.021" lash it calls for and also 0.017"
_______I__N__T__A__K__E
Rocker_Arm_Ratio_=_1.650_________Valve_Lash_=_0.02 100________Valve_Angle_=_20.0
VALVE_____Lift______Opens___Closes__Duration
_________________Deg_BTDC__Deg_ABDC_____________Ar ea
_________0.00000____47.69_|__84.37_|_312.05_|__61. 01
_________0.00600____44.55_|__80.80_|_305.35_|__60. 99
_________0.01000____42.73_|__78.67_|_301.39_|__60. 98
_________0.02000____38.71_|__73.99_|_292.70_|__60. 91
_________0.04000____32.32_|__66.84_|_279.16_|__60. 69
_________0.05000____29.68_|__63.94_|_273.61_|__60. 56
_________0.06150____26.89_|__60.95_|_267.84_|__60. 37_►_(.050*1.65)-.021=0.0615
_________0.06550____25.97_|__59.96_|_265.93_|__60. 31
_________0.10000____18.96_|__52.59_|_251.56_|__59. 70
_________0.15000____10.52_|__43.84_|_234.35_|__58. 68
_________0.20000_____3.06_|__36.19_|_219.26_|__57. 27
_________0.25000____-3.97_|__29.07_|_205.10_|__55.41
_________0.30000___-10.85_|__22.20_|_191.36_|__53.71
_________0.35000___-17.79_|__15.20_|_177.41_|__51.04
_________0.40000___-24.96_|___7.98_|_163.03_|__48.74
_________0.45000___-32.52_|___0.38_|_147.86_|__45.30
_________0.50000___-40.80_|__-7.88_|_131.31_|__41.46
_________0.55000___-50.19_|_-17.26_|_112.55_|__36.16
_________0.60000___-61.45_|_-28.50_|__90.05_|__29.76
_________0.65000___-76.72_|_-43.55_|__59.73_|__20.32
Rocker_Arm_Ratio_=_1.650_________Valve_Lash_=_0.01 700________Valve_Angle_=_20.0
_________0.00000____50.15_|__87.08_|_317.23_|__61. 64
_________0.00600____46.57_|__83.12_|_309.69_|__61. 62
_________0.01000____44.55_|__80.80_|_305.35_|__61. 61
_________0.02000____40.22_|__75.74_|_295.97_|__61. 50
_________0.04000____33.48_|__68.09_|_281.57_|__61. 30
_________0.05000____30.71_|__65.07_|_275.78_|__61. 15
_________0.06150____27.83_|__61.95_|_269.78_|__60. 98
_________0.06550____26.89_|__60.95_|_267.84_|__60. 91_►_(.050*1.65)-.017=0.0655
_________0.10000____19.71_|__53.37_|_253.08_|__60. 20
_________0.15000____11.15_|__44.49_|_235.64_|__59. 16
_________0.20000_____3.64_|__36.78_|_220.42_|__57. 71
_________0.25000____-3.42_|__29.63_|_206.21_|__56.06
_________0.30000___-10.30_|__22.75_|_192.46_|__54.09
_________0.35000___-17.23_|__15.77_|_178.54_|__52.11
_________0.40000___-24.38_|___8.57_|_164.20_|__49.07
_________0.45000___-31.88_|___1.01_|_149.12_|__45.60
_________0.50000___-40.10_|__-7.19_|_132.71_|__41.73
_________0.55000___-49.39_|_-16.45_|_114.16_|__36.93
_________0.60000___-60.46_|_-27.51_|__92.03_|__30.55
_________0.65000___-75.22_|_-42.07_|__62.72_|__21.75
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 02-16-2024, 01:11 PM
slowbird's Avatar
You'll never learn anything, but you are good at claiming other people's dyno sheets and making up false info.
Old 02-16-2024, 01:26 PM
Gach's Avatar
I’m glad you bought that up, let’s see you’ve posted at least 3 different dyno sheets, I have them all. I sent that one to Paul as a joke, because it list motor as BBF, 3 guys pick up on that right away in that thread. Your excuse was oh they labeled it wrong, to funny. Lets see guys dynoing your motors and he all of a sudden labels it as BBF. By mistake. Give me a break. Your problem is I got your number, and expose you for what you are.
Old 02-16-2024, 01:46 PM
Stan Weiss's Avatar
I have over 20 Super Flow "SFD" files from dyno tests Brian has done on a number of different engines. I have 2 dyno sheets you posted. One was pull down right after I PMed you about what was wrong with it.
Stan
  #38
Old 02-16-2024, 02:37 PM
slowbird's Avatar
You sure do have my number
  #39
Old 02-16-2024, 02:58 PM
Gach's Avatar
Birds of a feather flock together. You also like to manipulate dyno sheets. that’s a known fact LOL. Have you graduated yet from David V class. Your a amateur at best. I mean off the wall chit !
Its also well know theres a small group of of trolls, here that zone in on my every post. Totally jealous of response I get. Not realizing how much it makes them look like fools.
Here’s best part, lobe lift, 4470/4360 Steve C it should be .4470/.4360 oh my god, it just slows the inexperience of cam lingo.
My conversation with.oh excuse me Bullet racing cams NOT ultra. Talking about cam lobes. A whole dissertation came up about these are only lobes we have for Pontiac stick block. I’m like this isn’t a stock block oh well we don’t have blanks for that, you can’t get blanks you would have to have whole new blanks made up, that would cost a Fortune. I’m like thinking Comp cam has them but you don’t. Just shows or at least makes me think, their waaay behind on times. Old school.
The sad part is you try to contribute to a thread, and the trolls are setting there waiting, taking it 90 degrees north. Beating their chest. Dad you where right don’t argue with people who are dumber than you because they’ll make you look dumb. Can we just get back to the original purpose of the tread. Over and out.
Old 02-16-2024, 03:08 PM
Gach's Avatar
How’s that BBF making out, you should get Stan to change that for you. It’s embarrassing. is it going to make it off the dyno this time. Yes having lunch with Dan Barton you are clueless. The only guy I know who answers a question with a question. I had your number a long time ago. Like I said birds of a feather flock together.
Steve c your up next.. oh wait I think its Stans turn, hurry up Slowbird is waiting in the wings, one lies and the other swears to it.
