The melting process is better. The iron and resulting castings may--or may not--be better, due to any one or a combination of the hundred things involved in producing cast-iron parts. A few variables: What alloy agents are intentionally mixed-in with the iron, and in what percentages? Are the alloy materials consistent? What elements/impurities are unintentionally or negligently mixed-in with the iron, and in what amounts? Are these impurities consistent, or random? How hot is the iron when poured into the mold? How fast is the casting allowed to cool? Quote:
Given the amount of iron that GM would melt and pour, it wouldn't surprise me to find that arc melting went WAY back. And it may be much like "powdered-metal, cracked-cap, near-net shape" connecting rods. Sounds all modern and improved...until you discover the REAL reason for powdered-metal, cracked-cap, near-net shaped rods is that they cost MUCH less to produce in quantity than old-style forged (or cast) and machined rods and caps. I bet if the volume is high enough, arc-melted iron costs less than crucible-melted iron. |
The Following 2 Users Say Thank You to Schurkey For This Useful Post: | ||
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
The Following 3 Users Say Thank You to hurryinhoosier62 For This Useful Post: | ||
The topic of differences between arc and crucible melting, specifically for cast iron, is interesting to me, but as Shurkey alludes, it's hard to know if the finished product performance improved or if the melting process is more about manufacturing cost than product performance. What impurities are reduced by arc melting and how do they affect the properties of the casting? How do those properties affect the performance of the cast part? In general, I'm asking what is the definition of "better" for a finished cast iron block or head? I'd expect the alloy content and cooling rates to play a bigger role on product performance than impurities but I'm just guessing. Quote:
I've downloaded a few GM docs about materials. Based on one titled "Armasteel and Malleable Iron Castings", it appears the "Central Foundry" was marketing both to other divisions and to outside customers. The parts applications they supplied was huge. This is why I guessed the arc-melting process may have been better suited for a variety of alloys and parts than crucible melting. Mike |
Yes there are other factors to the game also.
For instance I have heard that Pontiac aged there cast iron pieces long before machining them, and here once again it would be nice to know if that where true. Other things matter much also. I have ground on many a Ford head to find such porosity that plans made to port them to a certain level of air flow had to lowered, and I have just found this condition in a AMC head I just ported. So then to me with a condition like this, one has to wonder when, other then cylinder walls and lifter bores ware wise how much a good quality iron matters if there’s inclusions everywhere.
I was also told at that same time that iron castings for a lathe or mill have to be aged for years. Otherwise the final machining tolerance of the surfaces will move and be inconsistent. |
The Following User Says Thank You to MatthewKlein For This Useful Post: | ||
According to the guys on the Engine Power show, current OEM procedures balance engines to about 0.25 in-oz and the show strives to balance at 0.125 in-oz in house
Sent from my SM-S901U using Tapatalk Last edited by 70GS455; 10-09-2023 at 10:09 AM. |
Enjoyed watching this again. Luv the old footage!
Eric "Todd" Mitten '74 Bonneville 4dr Sedan (455/TH400/2.93 open) '72 LeMans GT (455/M-13/3.23 [8.5"] posi) '71 GTO Hardtop (400/TH400/3.07 12 bolt posi) ‘71 GTO Convertible (455HO/TH400/3.23 posi) '67 GTO Coupe (455/ST-10/2.93 posi) '67 Tempest Wagon (428/TH400/2.56 posi) Deuteronomy 8:3 |
PMD's engine lead designer's son-in-law told me the Lead designer not only designed the Stratostreak from beginning to testing, but also had some say in modifying the GM CFC (Central Foundry C) processes in the cast nodular iron process.
As if he lead the process for cast steel. We'd all figure that a team of specilized metallurgist were needed, and I assume they were a tight team. |
