Old 04-15-2023, 02:02 PM
steve25 steve25 is offline
Default Coincidence ?
2.11” intake .
Max seat OD of 2.11” x 3.14 = 6.625 circumference.
Stock Pontiac Rod ratio = 6.625.
Old 04-15-2023, 02:04 PM
Considering the early Pontiac V8 engines all had smaller intake valves than 2.11” before 1967 I’d have to say it’s a coincidence.
Old 04-16-2023, 09:39 AM
Stan Weiss's Avatar
2.11” intake .
Slow Day.
If you only use 2 decimal points for pi then you really should show 2 decimal points in your results.
► 2.11 * 3.14 = 6.6254 which rounds to 6.63
► 2.11 * 3.141 = 6.62751
Stan
Pontiac Pump Gas List
Old 04-16-2023, 10:15 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Stan Weiss View Post
Slow Day.
Stan
Intetesting, I'm thinking 6.630 is just about the length of the old "rubber" rods while the engine was running.... Maybe there is something more to this.
Go fast, see Elvis!
Old 04-16-2023, 10:29 AM
Lol!
Yes Stan, bored while doing a wash load.
The amount those non heat treaded rods stretched was highly dependent on the stroke as I recall from a test done decades ago.
In a 317 cid motor they would last a long long time at 6K rpm.
in a 455 shifting at 6K even with light pistons and pins , the small end lightened up , fully polished and steel shot peened , ARP rod bolts ,they would not make it thru a complete weekend after weekend race season.
I was lucky I did not loose a block when two of mine went south.
Old 04-16-2023, 10:53 AM
Tom Vaught's Avatar
Boost Engineer
You can make numbers say anything you want and your post is a perfect example of that.
But it was worth a smile in the morning.
Tom V.
Old 04-16-2023, 11:26 AM
That’s all I intended it to be was a stumbled on smile.
Old 04-16-2023, 02:51 PM
Half-Inch Stud's Avatar
Windeler would probably like to remind the folks that the Stratostreak was laid out to allow growth is a Parametric manner.
Go figure the Bore Spacing and Deck Height allowed a 265 to grow to 472 (+060..) for same rod length. I suppose the Big Valve 455 is the Big-Stratostreak.
Old 04-16-2023, 05:11 PM
PAUL K's Avatar
Lol!
Probably, along with RPM, reciprocating weight and a bunch of other factors.
Go fast, see Elvis!
