Old 07-10-2022, 02:38 PM
69hardtop 69hardtop is offline
Default 70 455 HO Plug Wire Routing
I have one spark plug wire bracket I cant seem to figure out where it needs to go. It’s a 1970 455 HO that I just dropped into a 64 GTO. All the wire brackets came off the engine (which was pretty original) but my “before” pictures don’t clearly show where this one goes. It’s marked LH and has a square tab so I’m pretty sure it doesn’t attach to the valve covers. Back of drivers head maybe ?
Appreciate the help…..thx
Old 07-10-2022, 03:00 PM
Jason67's Avatar
Jason67 Jason67 is offline
Here: https://forums.maxperformanceinc.com...=834941&page=4
Post #65, first pic. Outboard(towards the steering column) of the Drivers side lower rear valve cover bolt on the head.
Jason
Old 07-10-2022, 05:52 PM
Thank you, but maybe I’m missing something here; the tab on the bottom is square (whereas the other three I’ve already mounted to the valve covers) are rounded and fit the valve cover profile for the bolt. Yours bolted up using the valve cover bolt ?
Old 07-10-2022, 05:55 PM
Got it ! It’s the boss on the head….stuck my hand down there and felt the open bolt hole. The orientation in you picture helped a lot
Thx….now just have to find the correct bolt
Old 07-11-2022, 05:00 AM
Held for Ransom's Avatar
https://forums.maxperformanceinc.com...d.php?t=853538
This would have been a good thread too.
So long, farewell.
Old 07-11-2022, 07:28 AM
Thank you ! The thread you suggested was perfect, not sure why it didn’t come up when I searched “spark plug wire holders” I also have that single wire holder leftover so I learned even more. Thx again
