Still looking for help here. I checked spark at the 1st plug looks good there. |
Pop the distributor cap and check to see if you have a bad rotor/cap..........It takes air,fuel and fire + compression to get a start.......Something aint there.
Karl |
Good news, did you double check rotor button to top dead center in relationship to cylinder#1 ? This can tell you if it's 180 degree off. You can be a tooth off and still rotate the distributor to get you close to run. Double check plug wires are in the correct place. These are just some more basic things to check. With the statement of it trying to run on starter fluid tells me you are close.
Ok distributor is slightly off number one
Pic attached. Not 180 but off. |
It is pointing at #2..... Rotate to #1 and it may start.....
Karl |
Fixed it for you!
Thanks for the help! I'll drink a Baker's Bourbon for you.....
Karl |
I asked him about the timing. He told me the distributor had not been touched since the engine builder (VERY reputable) had set it on their engine dyno. It was pulled off the dyno, crated, shipped to the owner, and directly installed. Long story made short, I ended up pulling right at 30 degrees of timing out of the tune. SOMEWHERE between the builder's engine dyno and my chassis dyno, the distributor had been bumped hard enough to turn it 30 degrees. ALWAYS double-check the timing after installing a new motor. Overheating went away, and RWHP increased by 60, BTW.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Well after going over everything else went back down the list an noticed that there was no fuel or very little coming out of the front bowl. Seems like what was in there was drained. Float looked low also...check fuel directly from the main fuel line nothing came out when the engine cranked. Went down to the fuel pump and checked from there nothing coming out direct from the out outlet. Removed fuel pump then reset it back. Tried again nothing...well thats it for today. Never would have thought this would be an issue. Not sure why the pump is not pumping will try again tomorrow.
The pump was involved in the last motor explosion...but seemed fine. You know its just bizarre how something pop up when you think all good here. |
Good to see your on to a problem.....and it's not electrical! That can of starting fuel was telling you something?
Thru many years of diagnosing, I firmly live by the rule of presume nothing. |
Make sure the fuel pump eccentric was installed to the camshaft. You can see if its in place looking thru the fuel pump hole in the timing cover. May need a mirror.
While the pump is off, carefully connect it to a fuel can and work the lever. You should be able to pump a good stream of gas.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
Did you check the coil? Weak/shorted coil = weak spark. Assuming same carb as test run. Check plug gap if not checked. Check to see if distributor is loose and could have shifted.
Prime the motor fuel wise, it's easy!
Take a normal cap from a spray paint can and fill its smaller center round section up with gas, the open the Carbs choke and pour half the gas down into each primary side of the Carb. If you have good enough spark and compression the motor will start and run for 3 to 4 seconds proving out a fuel supply issue! |
Have you confirmed Marks question yet regarding accelerator pump shot?
How old is the gas?
___________________________________ "Objects in mirror are closer than they appear" |
The system is not getting gas... from the fuel pump. I am going to look at that again tonight and check the installation of the pump again. Gas is almost 6 months old.
I'm in Manassas, can swing by this weekend if you want. PM me and will give you my phone number.
#38
Maybe there is no fuel pump eccentric on the cam?
Maybe someone assumed you were running an electric pump. |
#39
I called the shop this morning..with the exact same question, said it was installed. I am going to take it apart tonight and take a look then reset it again.
#40
