Timing Chain length
Ok another question
How does one go about measuring the length of chain u need ....whether it be standard.... or .005 or .010 shorter......
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
I got this from Rollmaster
HOW TO DETERMINE TUNNEL BORE SIZES AFTER FITTING YOUR STANDARD ROLLMASTER TIMING CHAIN SET TO THE ENGINE YOU NEED TO PINCH WITH TWO FINGURES THE CHAIN HALFWAY BETWEEN THE CRANK AND THE CAM SPROCKET ON THE RIGHT HAND SIDE. WITHOUT FORCING OR PUSHING HARD JUST MOVE THE CHAIN BACK AND FORTH AND NOTE THE AMOUNT OF MOVEMENT. USE THIS FORMULA 1/4" = .002 TO .004” 5/16” = .004 TO .006” 3/8” = .006” TO .008” 1/2” = .008 TO .010” THESE SIZES ARE THE AMOUNT OF THE OVERSIZE YOU NEED TO ORDER TO OBTAIN THE BEST POSSIBLE RESULTS FOR CHAIN FITMENT. **HOW TO ORDER AN OVERSIZE OR LINE BORE TIMING SET** ADD TO THE STANDARD P/N THE OVERSIZE YOU FOUND FROM THE DEFLECTION MEASURED . EXAMPLE CS1000-006 THIS INFORMATION INFORMS ROLLMASTER THAT YOU NEED A SMALL BLOCK CHEV SET THAT IS .006 THOU LARGER ON THE CAM SPROCKET. ROLLMASTER SUGGEST THAT YOU KEEP ONE STANDARD TIMING SET FOR REFFERENCING EACH ENGINE TYPE YOU USE. THE SIZING OF OUR STANDARD TIMING SETS WITH IWIS CHAIN WILL NOT VARY AS EACH SET IS MATCHED PAIRED FOR EXACT CENTER TO CENTER DISTANCE. THIS WILL ALLOW YOU TO MAINTAIN A CONSTANT RELATIONSHIP BETWEEN STANDARD CENTER TO CENTER DISTANCES AND LINE BORED BLOCKS. HOW DOES THIS WORK AND WHY ? WHEN YOU MACHINE THE ENGINES MAIN BEARING TUNNEL THE DISTANCE BETWEEN THE CAMSHAFT AND THE CRANKSHAFT CAN BECOME CLOSER CAUSING A STANDARD SET TO FIT WITH SLACK IN THE TIMING CHAIN. ROLLMASTER SOLVES THIS PROBLEM BY MANUFACTURING SPROCKETS SLIGHTLY LARGER IN THOU INCREMENTS. THE LARGER SPROCKETS ARE SIMILAR TO ENGINE BEARINGS BEING THICKER FOR CRANKS THAT HAVE BEEN GROUND. THE RESULT IS THE LARGER SPROCKET TAKES UP THE SLACK IN THE DISTANCE BETWEEN THE CRANK AND THE CAM AFTER MACHINING. DO NOT USE CHAINS THAT CLAIM TO HAVE SMALLER PITCHES AS THESE SOON WEAR AND YOU END UP WITH A POOR FITTING TIMING SET VERY SHORTLY AFTER. DO NOT MIX AND MATCH ROLLMASTER TIMING SPROCKETS AS THESE ARE MATCHED PAIRED. ROLLMASTER LISTS FACTORY CENTER TO CENTER DISTANCES FOR MOST POPULAR ENGINES ON THE FRONT PAGE OF THIS WEB AT THE Sprocket Data Button. THE INFORMATION SUPPLIED HERE IS A GUIDELINE ONLY. USER DISCRETION IS REQD. |
cool info thanks
