Manual rear mount antenna (66 gto)
Not sure if they originally came out on the 66 gto, but was wondering if they repop rear mount manual antennas for a 66gto. If so who makes them? Or is there an alternative?
Manual mount antenna was only on the right front fender.
The only rear mounted antenna was a power antenna which mounted on the right rear quarter panel.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
The 66 and 67 Chevelles had them on the right quarter panel, straight up mast. Maybe check OPG, NPD, and Ground Up to see if they are reproduced. Also, look at Corvette Central to see if any Corvette antenna's would work for you. Team Chevelle has a good forum with parts for sale also.
You may have to mix Tempest, LeMans, GTO parts with the Chevrolet parts for a good fit on the quarter panel. I don't think any will retract, if that's a problem. Jim |
