Web Rodder engine build article resurrected...
Thanks to YUKU member CR for posting this over on the OHC pages...
Part 01 (Machine Work) http://www.webrodder.com/article.php?AID=335&SID Part 02 (Cleaning and Paint) http://www.webrodder.com/article.php?AID=336&SID Part 03 (Crank, seals, freeze plugs) http://www.webrodder.com/article.php?AID=341&SID Part 04 (Oil pickup, pickup height, dipstick, crank seal) http://www.webrodder.com/article.php?AID=342&SID Part 05 (Rods and Pistons, Balance and Assembly) http://www.webrodder.com/article.php?AID=345&SID Part 06 (Slamming rods and pistons home, plus ring tech) http://www.webrodder.com/article.php?AID=346&SID Part 07 (More assembly head, pan, plugs) http://www.webrodder.com/article.php?AID=347&SID Part 08 (Oil pump module, fuel pump, water pump, inner cover) http://www.webrodder.com/article.php?AID=348&SID Part 09 (Ignition, Pertronix conversion, plugs and wires) http://www.webrodder.com/article.php?AID=349&SID Part 10 (Head and valvetrain confusion – or not) http://www.webrodder.com/article.php?AID=360&SID Part 11 (Cam Tower Mysteries) http://www.webrodder.com/article.php?AID=362&SID Part 12 (Cam timing issues and solutions) http://www.webrodder.com/article.php?AID=365&SID Part 13 (Rebuilding the Q-Jet carb) http://www.webrodder.com/article.php?AID=373&SID Part 14 (Finishing the Q-Jet carb) http://www.webrodder.com/article.php?AID=374&SID Part 15 (Manifolds and final assembly) http://www.webrodder.com/article.php?AID=378&SID
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
The Following 3 Users Say Thank You to Jeff Hamlin For This Useful Post: | ||
Ok is it just my computer of do some of these lead to a blank page the pertronics page in particular
When you really do something right it's like you didn't do anything at all 1931 Pontiac 5 window coupe OHC6 powered 2015 GMC Yukon SLT |
just checked, and i was able to get to all links
Jon Peters 66 tempest 3880 lbs with driver 455 .40 over, 6x, XE274H cam, th350,9 inch 3.89, 275/50/15 mt dr 13.04 et / 102.51 mph 11.97 et/ 113.68 mph w/150shot 75 Astre Turbocharged OHC 6, TH350 1/8 mile stats 8.4813 ET / 82.07 MPH |
I just get a web rodder page with no
Text except a link to purchase
Working on both mine.
Check your settings, you may be blocking it.
