Old 08-02-2013, 09:43 AM
1966geeto 1966geeto is offline
Default Band clamps
Getting ready to re install exh system looking at Walker band clamps what do you guys think of them looks like the clamp bolts may interfere with other components not a fan of the u clamps but they make taking the system apart impossible .Do the band clamps seal just looking at options for future exh removal.Thanks
Old 08-02-2013, 09:48 AM
Brad Pringle's Avatar
Brad Pringle Brad Pringle is offline
Default band clamps
I love mine that a 2.5" wide and cover the whole seam. Will not use anything else now!
Brad Pringle
Wellston, Michigan
1973 SD 455 TA Auto
1974 SD455 TA 4 Spd
Old 08-02-2013, 01:39 PM
oldblueponcho's Avatar
oldblueponcho oldblueponcho is offline
I haven't used anything but band clamps for years. They seal perfectly, and make disassembly a breeze.
Some Fear, Because if you've never been afraid- just a little. You're obviously not going as fast as you could be.
Old 08-02-2013, 01:56 PM
ta man ta man is offline
When I swapped cars..I pulled my old exhaust off in about ten minutes....Band Clamps
Old 08-02-2013, 02:51 PM
quicksilver97ta's Avatar
Does an exhaust come apart easier with band clamps vs regular clamps?
Old 08-02-2013, 03:22 PM
David Jones's Avatar
Many times a regular "U" clamp will crush the pipe enough to make separation of the pipes a chore.
Old 08-02-2013, 04:11 PM
Default size
Does the clamp compensate for diff in od sizes ? when you slip the pipe in the wider side how does the clamp seal the difference in the pipe overlap, and if you do not have a slip joint can you use them to fit 2 pipes of the same sixe butted up to each other ?
Old 08-02-2013, 04:31 PM
MrWrestlingII's Avatar
MrWrestlingII MrWrestlingII is offline
To seal the type of joint you're speaking of you'd use a stepped band clamp. The stepped clamp conforms to both the large/small OD of the joint.
If you were sealing a butt style joint you'd use a straight band clamp which is the same diameter for the length of the clamp.
1970 GTO-vert, 461, eheads, stump puller, m20, 3.42
Old 12-12-2013, 05:40 PM
HJones1313's Avatar
HJones1313 HJones1313 is offline
Send a message via Yahoo to HJones1313
I'm done with "U" clamps, and will only use band clamps, since they make it so you can pull the system apart if you need to. The U clamps make a crush seal, and make it difficult to take them apart.
"GTO......Gas, Tires and Overdraft"!
'70 GTO convertible, 434, 4-speed
Old 12-12-2013, 05:47 PM
nytrainer's Avatar
Good topic. Was wondering if you put anything on the pipes before the band clamps go on.(Neverseize or ?)
Old 12-12-2013, 09:08 PM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
Default Band Clamps...
I use band clamps and i use antiseize on the slip fit joints...
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
Old 12-12-2013, 10:16 PM
Will never use a u clam again expensive but well worth it.
The Following User Says Thank You to 1966geeto For This Useful Post:
Old 12-13-2013, 03:17 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
All band clamps on the 2.5" exhaust of the '59 GMC I'm doing. Only used anti-seize on the clamp bolts/nuts. I also put a small stainless self-tapping screw into every pipe-end/band-end, mainly to guard against rotation of mufflers or pipes.
I did initially have a problem with the clamps (of unknown origin)- I bumped the old 2009 'Band clamps' thread up for reference (see my post#8 to that thread).
Old 12-13-2013, 03:00 PM
I see that a couple of other guys use anti seize. I put a bead of clear silicone on the pipe that goes inside the flange. Some of it burns off, but some of it stays and helps s to seal. When you want to take the system apart, you only need to twist the joint a bit and it comes right apart.Don't use red, blue or black silicone as it will cement the joint together and make it difficult to disassemble.
Old 12-13-2013, 05:24 PM
Best thing for us guys that wind up changing everything every couple years.
Old 12-13-2013, 09:46 PM
TSMartin TSMartin is offline
I use the "generic" 3" lap clamps from Summit on my system. I've had it apart to swap out the mufflers and it went back together with no problem. I'll be taking it apart again to reroute my piping this winter. Use anti seize on the bolts and tighten the p*** out on them. They are easy to orient so the clamp bolts won't interfer with anything.
TS
Old 12-14-2013, 10:47 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have tried them on two cars and could get neither to squeeze enough to seal. If there is any difference in diameter they just wouldn't do it.
Skip Fix
Old 12-16-2013, 02:03 PM
HWYSTR455's Avatar
Regular street use I weld them. If I need to replace them in a 5-7+ years, so be it, it's the cost of regular street use IMO. Same with stainless, I say use aluminized and replace as needed.
You bottom out or catch a lip in a transition, like going into a parking lot or something, it will rip it apart, and forget putting it back together with band clamps. Might not be a concern for some, but I drive my stuff hard, and stuff happens.
