Old 06-24-2005, 08:31 AM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
ok, i was installing my headers and it came to the part of putting the gasket on and i wasnt sure on how it goes, on the gasket it has a rough side and a smooth side, does the smooth side go to headers and the rough side to the block or is it the other way?
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 06-24-2005, 10:16 AM
6567GTO's Avatar
6567GTO 6567GTO is offline
either way will do but use this silicone that is available at most auto parts stores. Use it on both sides of the gasket. Don't put too much on either. Let it sit overnight to cure. After a weeks worth of running, retighten the bolts.
_________________________
Sonny Barger
