#61
And a good tuner that is willing to share. What the valve sizes on the Warp6 head George?
#62
Heads
Scott Quote: "What the valve sizes on the Warp6 head George?
I have no idea. GTO George |
#64
Off the subject, well not really... Has anyone ever cut a tiger, e, kre or cast iron in half???
#65
What is the difference between a Pro Stock Chassis and a Pro Mod Chassis ?
You know it's going to be a good day when you wake up breathing! |
#66
The new first gen bodies will take the same tire as a fuel car, pro stockers normally will not fit this tire. I believe in NHRA/IHRA a nostalgia body is mandatory in pro-mod now as well. There are builders offering Titanium options for ADRL pro mods. Basically any bar that isn't necessary for the sfi spec is being replaced with lighter titanium bars. ADRL had no weights minimums up to last year. That may have changed, I do not keep up with their rules. |
#67
Eric |
#68
Now that we've explained how the Ford gets away with 4 per cyl, and ignored the fact that the 97 and up LSx GM motors do have problems, can we look at that?
They don't have side by side exhaust ports, but they do lift the heads when given enough boost or nitrous. The LSX motor was built almost right away by GM as they knew there was a problem. And it didn't matter if you used a iron block and aluminum head or both were aluminum. Just trying to add more info into the mix to find a reason. Maybe it's just a GM thing. |
#69
ive been out of serious drag racing for a while, with all these big inch Chevy based motors & hemis i find it hard to believe a pontiac even competing
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored) 1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505 1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS AC Cobra Kit Car 521 670 HP/715 Trq LOOKING FOR V PARTS !!!!!!!!!!!! |
#70
I have heads in my possession that I cut up, no need to post pictures for me.
#72
To be honest, I do not pay real close attention to big tire cars. They are not as interesting as small tire cars, IMO. |
#73
Thanks Mark. |
#74
I dont have a camera here at work to take an pictures.
#75
I would be interested in any pics, especially center area of heads herbhagan@yahoo.com
74 Ventura 462/#13 heads/3350# 10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured |
#76
Not that it is set in stone - but most current Pro Mods are a double frame rail affair and most pro stock are not - some flex in the right place is not really a bad thing
#78
Scott Roberts took a similar approach but with a larger bore.
#79
Going Pro Mod
If I had it to do all over again, I would shrink my bore down to 4.21" and up my stroke to 4 5/8"
GTO George |
#80
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
