Here's a false boundary condition: If the engine can start & idle then the cam is not too big.
Pretty sure i've attained "too big a cam" and starts & idles. Only benefits are nice sound & no ping. A right-sized cam is most desirable, and should be desired. Same goes for TQ Converter stall & tightness.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Agree with others the cam choice will be a torque monster and work just fine. I like the 114 LC as well. From recent experience, at 500 Cubic inches, the exhaust manifolds will be a detriment. I do not know personally how much better the round port SD manifolds are than the D-port long branch I recently installed. But on the dyno, they killed almost 30 ft. lbs of torque everywhere from 3500 RPM to 5500 RPM. Possibly the SD manifolds are much better? My engine was only 462 CU IN. similar compression ratio, 10:1. The weak link from everything you listed is the Muncie transmission. Not to pick on them specifically, a BW super T-10 would fair no better. These little 70 lb. aluminum transmissions just were not designed for the kind of torque you will be making. On street tires, if you don't go crazy banging the gears, it will live for a while. I have the same Muncie in my car making 450 HP. and anticipate it flying into pieces at some point in the future. Then I will have an excuse to swap-in a 5-speed. Your car will be fun!!
No lifter bore bracing is necessary.
I will offer this suggestion, have your old valve springs tested to see how much pressure they have lost. Keep in mind the additional weight of those larger 2.190" diameter springs. Test them with a calibrated bench tester like a Rimac machine at their verified installed height with their retainers in place. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 10-31-2022 at 10:49 AM. |
Thanks Murf |
Sorry for hijack. Back to topic. |
The 5 and 6 speeds are pretty stout by stick shift standards. The TKO's have been pushed beyond their advertised ratings for decades being used in drag race applications. 6 speeds as well.
Of course they can all be beefed further if need be. Many places offer that service, but for a street car that might see a fun dragstrip day once in a great while, I wouldn't even worry about it. If you still use stock rearend and driveshaft components, I'd be more worried about those before that TKO gives up. Street car with street tires, have fun and don't worry about it. |
There was a iron case,steel midplate ST-10 2.64 first gear made some years ago for NASCAR.Also had high nickle gears.Bill Blair offered me one years ago and still kicking myself for not buying it.FWIW,Tom
This is how the engine and trans changed along with the results. Changes Long tube headers, T-56 Tremec and 3.73 rear.
https://forums.maxperformanceinc.com...d.php?t=834864 Videos: https://www.youtube.com/watch?v=LCVaZqP-PNo&t=46s https://www.youtube.com/watch?v=qA3K-ydGsGo Last edited by napster; 10-31-2022 at 01:04 PM. |
FWIW, your question at the beginning of the thread made me think of a quote in one of the member's signature.
Too much cam? Quote:
Sorry for the hack - I did warn I was a newbie! |
It won't be apples-to-apples but here was my back-to-back testing of a Performer RPM intake and a Victor intake on this engine:
https://pontiacstreetperformance.com...455sc2003.html Both intakes were port matched to the heads in use. RPM intake 580.2 HP at 5800 rpm (peak) and a Victor intake 600.9 HP at 6000 RPM (peak). RPM intake 589.1 ft.lbs. torque at 4400 RPM (peak) and the Victor 595.1 ft.lbs. torque at 4700 RPM (peak). Down low, the Performer RPM with 491.2 ft.lbs. torque at 3500 RPM and the Victor intake 487.0 ft.lbs. torque at the same 3500 RPM. .
There is such a thing as too much cam. A friend recently put a CC 305H into a 7.9:1 compression, 300 cubic inch v8 and couldnt get it to start. It has provided me with a lot of material to make fun of him with.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
