Old 07-13-2016, 12:01 PM
70peppergreen 70peppergreen is offline
Default blowing out fuel and brake lines
I have a 70 GTO I am painting the under body frame on, with professional automotive black
I removed the brake and fuel line and blew them out with paint thinner and compressed air
the question is does any one know how to blow out the distribution block and the block in the rear.
i have front disc and power booster if helps
should i hook up a short tube to each fitting on the blocks and use compressed air with paint thinner
any experience helps
Old 07-13-2016, 01:35 PM
marxjunk marxjunk is offline
no thinner thru any valve or rubber brake hose...ever...
pump brand new brake fluid thru them...
get some in the hard lines if it sets...the thinner strips the the lubricity out of the lines and they flash rust
thinner kills seals its too caustic..pump new fluid or just air thru the valves..they have an o-ring and thinner kills it instantly
you can disassemble the prop valve..very simple..just make sure you put it back the way ypu took apart
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
