Old 08-09-2004, 05:28 AM
78 GHOST 78 GHOST is offline
I'm curious about the potential (in HP and TQ) of a 1970 455 with 64 heads. Street manners are secondary, but of some importance.
Parameters:
HEADS
-Aftermarket heads are totally out of the question.
-Also assume the stock 64s could be worked as much as possible/needed.
-In addition, assume the use of any internal component readily available. This includes rollers, coatings, special cranks, rods, pistons, rings, etc.
BLOCK
-Assume filling if need be. However, it must be street drivable with a factory radiator. Good manners is a must.
-I don't mind sleeves
-Valley braces are OK
CAM
-Rollers are fine
-Lifters are open to anything
-Can't sound like it's 8 strokin' (must sound close to stock)
-Will be using P/B, however a can is possible.
-Don't worry about vacuum too much
INDUCTION
-Factory iron spreadbore manifolding.
-Well prepped Q-Jet
-Factory 3/8" supply
-In-tank electric pump.
EXHAUST
-RA long branch manifolds
-Must run mufflers which sound close to stock
Chassis setup:
TRANSMISSION
-TH400
CONVERTER
-Whatever
DIFFERENTIAL
-12 Bolt Limited slip
-Pretty much any available ratio (was thinking
3.73:1 or 3.55:1)
SUSPENSION
-STOCK
-PolyGraphite bushings
TIRES
-You guessed it
In addition, I'm not mentally locked into the 455, it merely suits the car I have. The other possibility is a 400, but I didn't wish to start out at a C.I. disadvantage.
Any thoughts?
____________________________________
"I work in high speed aluminum tubing."
Parameters:
HEADS
BLOCK
CAM
-Rollers are fine
INDUCTION
-Well prepped Q-Jet
EXHAUST
Chassis setup:
TRANSMISSION
-TH400
CONVERTER
-Whatever
DIFFERENTIAL
3.73:1 or 3.55:1)
SUSPENSION
-STOCK
TIRES
-You guessed it
Any thoughts?
Old 08-09-2004, 03:17 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Hey Matt, gimme a call.
I REALLY like the combination in my Blue Formula, and it has LOADS of usable torque. Remember, I'm running OEM heads, intake and exhaust manifolds, a 3.08 gear and ONE muffler!
Regards,
"455HO" Lloyd
Old 08-10-2004, 06:55 AM
Nickv's Avatar
Nickv Nickv is offline
Funny you mention that.
my 67 has a 70 455 +0.030 over with Stock uncut #64 heads, 1.65HS roller rockers, CC Pushrods,Lunati double springs, CC292 cam, Torker I, 850Holley DP with 82/86 jets, TRW pistons with SD Rods, studs for the mains. 4 tube headers with 3" exhaust, 3:73 gears, TH400 w/3000 stall car runs N/A 12.5@106. With 150HP NOS runs 11.5@116. Car weights around 3600lbs with me in it. Good street manners, though with that cam it's got a prostreet sound to it. But the car is driven everywhere and has about 30 1/4 mile passes since I've owned it, and close to 80 1/4 mile passes on the shortblock from the previous owner when it was a dedicated drag car. The engine was built in 1991 and is still going strong.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecarsgalore.com
www.nikivee.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger ScatPack 392, 6 speed
2017 Ford Explorer AWD
Old 08-10-2004, 07:29 AM
Mo's Avatar
Mo Mo is offline
How does 12.56@ 107.6 ,4290lb race weight with long branch manifolds. A Paul Spotts built 462, ported #64 heads, P-RPM, now T2, lunati s/roller, BG carb,etc...very sreetable! Look up 69f bird, there is a link on his profile to his web page. Shelly allowed me to drive it once last summer . Awesome!
Systems under stress fail catastrophically
Old 08-11-2004, 11:25 AM
Junkyard Dog's Avatar
Sounds like somebody is going FAST racing.
Badder than old King Kong
-Jim Croce
