Old 04-06-2014, 01:41 PM
TA455HO's Avatar
TA455HO TA455HO is offline
Default NOS and Used early f-body parts
All prices are without shipping. Parts are listed as NOS or Used as applicable. Some of these are the last ones that I have. Once they are gone, they are gone.
3928380 - NOS pair of Body Mount bushings for position #2 Upper - These have the part number and the word CHEVROLET (which is correct for PONTIACS) molded into the rubber - very good condition - $125
3928380 9.023 F/6-F/8 INSULATOR, No. 2-- upper 2 1967 1968 9-2
3928380 9.023 F/6-F/8 INSULATOR, No. 2 2 1968 1968 9-2
3928380 9.023 All F INSULATOR, No. 2-upper 2 1970 1972 9-3
3928380 9.023 All X CUSHION ASM., body bolt, No. 2 2 1971 1972 9-6
3914802 - NOS set of 4 body bushing for position #2 Lower - 1967-1969 Firebird - These have the part number and the word CHEVROLET (which is correct for PONTIACS) molded into the rubber - $100
3914802 9.023 F/6-F/8 INSULATOR, No. 2-3-- lower 2 1967 1968 9-2
3914802 9.023 All F INSULATOR, No. 2 (lower) 2 1969 1969 9-3
3914802 9.023 All X CUSHION, body bolt 2 1971 1972 9-6
3901365 - NOS Body Mount Bushing Washers - Package of 5 - $20
3901365 9.011 All F WASHER, No. 2-3 body bolt (1%2'' I.D. x O.D.) 2 1967 1975 9-1
3901365 9.011 All X WASHER, body bolt (21/32'' I.D. x 21/2'' O.D. AR 1971 1975 9-1
3901365 1.270 F ......................... SHIM, BAD BFL FROM MT BRK TO FRM 1) AR 1976 1981 1-38
3901365 1.270 F ......................... WASHER, RAD BFL FROM MT BRKT TO (9.011) AR 1976 1981 1-39
3901365 9.011 F ......................... WASHER, BODY BOLT (21/32'' I.D. X 21/2'' (ALSO LISTED 1.270) AR 1976 1981 9-1
AC Parts
1998999 - NOS Diverter Valve Vacuum Diaphragm - $100
1998999 8.850 All B, G A.C.-- (9.280) DIAPHRAGM, diverter valve 1 1965 1972 8-36
1998999 8.850 All F/A.C.-- (9.280) DIAPHRAGM, diverter valve 1 1970 1975 8-37
1998999 9.280 All B/A.C DIAPHRAGM, air inlet-upr 1 1965 1968 9-33
1998999 9.280 All B, G/ATC A.C DIAPHRAGM, air inlet-upr 1 1969 1972 9-33
1998999 9.280 F, X/A.C DIAPHRAGM, air inlet-upper 1 1975 1975 9-33
9774799 - NOS Valve - Gold Cad looks perfect - This is a show quality piece not refinished - $125
9774799 9.795 P/8 A.C ................. VALVE 1 1967 1968 9-61
9774799 9.795 All A.C .................. VALVE (w/threaded tube) 1 1969 1969 9-61
9774799 9.795 All A,F/A.C .............. VALVE 1 1970 1971 9-61
3909030 - NOS Freon Hose Clamp - $5
3909030 9.242 All A.C CLAMP, freon hose (3/4'' I.D.) 1 1959 1974 9-20
1115881 - NOS AC hi-blower Relay - $65
1115881 9.277 All F, X/A.C RELAY, hi-blower 1 1970 1971 9-33
1115881 9.277 All X/A.C RELAY, hi-blower 1 1972 1974 9-33
5914809 - NOS AC Compressor - $125 shipped
5914809 9.170 All A.C. w/6 cyl. comp CYLINDER AND SHAFT ASM 1 1962 1975 9-6
5914809 9.170 ALL W/AXIAL CMPR ........ CYLINDER, W/PISTONS, WOBBLE PLATE SHAFT 1 1976 1981 9-2
1115364 - NOS Vacuum Diaphram - Has the last three '364' stamped on the part - $130
1115364 2.410 All 455-H.O CONTROL (w/WC, WL, YE eng.) 1 1971 1971 2-40
988761 - NOS 1970 and 1971 Pontiac Tissue Dispenser and Litter Container - The Kleenex box inside of this one is copyright 1938 and 1966 - $200
988761 All ...................... DISPENSER PKG., tissue & litter container 1 1970 1971 A-2
3988524 - NOS Pinion Flange - $45
3988524 5.545 All F FLANGE (w/deflector) (use w/4.13, 4.11, axl 1 1971 1971 5-29
3988524 5.545 All X .' FLANGE (w/deflector) 1 1972 1975 5-29
3988524 5.545 All F FLANGE, w/deflector 1 1972 1974 5-29
3988524 5.545 X W/8.50 DIA RNGR ........ FLANGE, W/DEFL, PROP SHF PIN 1 1977 1979 5-25
1881371 - NOS distributor weights still in their wrapper - 1970 RAIII and RAIV with manual trans as well as other applications - $60
1881371 2.388 T/8 400 WEIGHT (w/WS, WT & YZ) 2 1969 1969 2-34
1881371 2.388 All Ram Air-H.T. (M-40) WEIGHT (w/YZ or XP eng.) 2 1970 1970 2-34
1881371 2.388 All Ram Air-IV-M.T WEIGHT (w/WW en9.) 2 1970 1970 2-34
1881371 2.388 All Ram Air III M.T WEIGHT (w/WS en9. & 1112024 dist.) 2 1970 1970 2-34
478558 - Used console backplate in very nice condition - Grain is perfect - $12
478558 10.240 F PLATE, rear cover 1 1970 1975 10-3
478558 10.240 F W/CNSL (D55) ............ PLATE, SEAT SEP RR CVR (BLACK) (PAINT MATCH) 1 1976 1979 10-2
478558 10.240 F ......................... PLATE, SEAT SEP RR CVR (BLACK) (PAINT MATCH) 1 1980 1981 10-2
9767113 - NOS Lower ball joints - still have protective caps and hardware - $90
9767113 6.174 All F BALL JOINT 2 1970 1975 6-4
9767113 6.174 All A, G BALL JOINT 2 1973 1975 6-4
9767113 6.174 All X BALL JOINT 2 1975 1975 6-4
482333 - NOS Pair of rear sway bar insulators - $80
482333 7.243 All F/Trans. Am INSULATOR (7/8" dia. shaft) 2 1970 1971 7-9
482333 7.243 Ale F/Formula INSULATOR (w/15'' wheels) (7/8" dia. 2 1971 1971 7-9
482333 7.243 All F/Trans. Am INSULATOR, w/firm ride (7/8" dia. shaft). 2 1972 1973 7-9
482333 7.243 F ......................... INSULATOR, RR SHAFT 2 1976 1976 7-5
3992571 - NOS bracket for proportioning valve - Silver Cad is in excellent condition - no pitting - not refinished - Has correct PM letters stamped into bracket - $50
3992571 4.690 All F/P.B BRACKET, valve mtg 1 1971 1975 4-19
3992571 4.690 All X/D.B BRACKET, valve mtg 1 1971 1974 4-19
3992584 - NOS rear brake cable - just one - $40
3992584 4.779 All F CABLE ASM. (rear) (66 1/2" long) 2 1970 1974 4-19
10003072 - NOS rear shackle kit - These also fit 1970 - 1975 but the shackle plates are shaped differently - These do include 4 of the 480902 bushings and the correct bolts - $85
10003072 7.523 F ......................... REPAIR KIT 4 1976 1981 7-12
10003072 7.523 x ......................... REPAIR KIT 4 1976 1978 7-13
1971247 - NOS D409R - Original Delco Remy rotor - box is faded but rotor is perfect - Delco Remy molded into plastic - $80
1971247 2.382 All exc. 3/2 B.C .......... ROTOR 1 1957 1958 2-26
1971247 2.382 All ...................... ROTOR 1 1959 1962 2-26
1971247 2.382 All V/8 .................. ROTOR 1 1963 1971 2-26
801816 - NOS Bridge Rectifier - 80 AMP alternators - $15
801816 2.319 All ...................... BRIDGE, alt. rectifier (w/80 amp. alt.) 1 1971 1971 2-16
801817 - NOS Tri-diode - 80 AMP alternators - $10
801817 2.319 All ...................... DIODE, negative-trio (w/80 amp. alt.) 1 1971 1971 2-16
1876641 - NOS distributor breaker plate package - string box still intact - $25
1876641 2.385 All B, G/428 H.T. exc. H.O PLATE, breaker (w/dist. 1112009) 1 1969 1969 2-33
1876641 2.385 All V/8 exc. 307 PLATE, breaker (exc. Unit Dist.) 1 1970 1971 2-33
1876641 2.385 X/307-A.T. or. H.T PLATE, breaker 1 1971 1971 2-33
1876641 2.385 X/307 M.T PLATE, breaker (w/1112005 dist.) 1 1971 1971 2-33
1876641 2.385 All V/8 PLATE, breaker (exc. uniset dist. or unit 1 1972 1974 2-33
1876641 2.385 All Uniset Dist PLATE 1 1973 1974 2-33
5535623 - NOS front shocks - stamped 3192132 - $450
5535623 7.345 All F .................... SHOCK PKG. (front) 2 1970 1971 7-9
5535623 7.345 B W/H.D. OR POL ........... SHOCK ABSORBER, FRT (MDSE 2 1976 1978 7-6
5535623 7.345 X ......................... SHOCK ABSORBER, FRT (MDSE 2 1976 1977 7-7
5535623 7.345 F (EXC FORMULA & TRANS AM) SHOCK ABSORBER, FRT (MDSE 2 1977 1977 7-7
5535623 7.345 F (EXC WS4, WS6, WS7, W66) SHOCK ABSORBER, FRT (MDSE 1154078) 2 1980 1980 7-7
5535623 7.345 F (EXC WS4, WS6, W66) ..... SHOCK ABSORBER, FRT (MDSE 2 1981 1981 7-7
3961557 - Used washer jug in good shape - slight yellowing - includes lid, hose and filter - $20
3961557 10.154 AllF.................... JAR 1 1970 1971 10-2
3961557 10.154 AllA&G............... JAR 1 1971 1971 10-2
481424 - Used cover for horn relay - Good condition - Part number molded into the plastic - $15
481424 2.815 All COVER, horn & key alarm relay 1 1969 1971 2-80
481424 2.815 All F COVER, horn & key alarm relay 1 1972 1973 2-80
Seat belt set - Standard buckles - Date coded January 22, 1971 - These were redone by snake oyl and are very good condition - $700
3798256 - NOS nylon pedal shaft bushings - Pair with original packaging - these are thicker than the reproductions - $20
3798256 0.831 F/6-F/8-T/6-T/8-GP/8 M.T.--(4.626) BUSHING, nylon 2 1966 1970 0-52
3798256 0.831 All A & G--(4,626) ...... BUSHING, nylon 2 1971 1971 0-52
3798256 4.626 All ..................... BUSHING, shaft(Nylon) AR 1961 1969 4-15
3798256 4.626 All exc. F/6-F/8 ......... BUSHING, brake pedal shaft (nylon) 2 1970 1970 4-15
1112072 - Used distributor - 1D25 (April 25, 1971) date code - spins freely - $40
1112072 2.361 All 455-4 B.C. exc. H.O DISTRIBUTOR (w/YC, WJ eng.) (exc. unit 1 1971 1971 2-25
1112070 - Used distributor - 1B5 (February 5th, 1971) date code - spins freely - $40
1112070 2.361 All 400-4 B.C DISTRIBUTOR 1 1971 1971 2-24
Old 04-06-2014, 01:47 PM
Pm sent
Old 04-06-2014, 02:22 PM
68 Firebird Brian's Avatar
68 Firebird Brian 68 Firebird Brian is offline
PM Sent
68 Firebird 400 HO vert under construction
65 Catalina Wagon TriPower 389 under construction
Old 04-06-2014, 05:38 PM
Pepi's Avatar
Pepi Pepi is offline
PM sent
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 04-06-2014, 09:36 PM
birdsandgoats birdsandgoats is offline
PM sent
Old 04-09-2014, 02:25 PM
Todd Mullin Todd Mullin is offline
I would like to have the used washing fluid jug and the brake porportioning bracket if they have not been claimed yet. Todd
Old 04-26-2014, 12:13 PM
Keats's Avatar
Keats Keats is offline
PM Sent Thanks
David Clark
1972 Trans Am Blue 4sp
1973 Grand Prix Blue 400/Auto/Bench
1974 Trans Am Blue 400/Auto
1979 Trans Am Brown 301/Auto
Old 06-26-2014, 04:49 PM
TA455HO's Avatar
If you still see pictures of an item it is probably still available. Let me know if you see something of interest.
Thanks,
Chad
Old 04-14-2017, 06:25 AM
Judge273's Avatar
Judge273 Judge273 is offline
Is the AC hi blower relay switch still available?
Mike/Illinois
Old 04-14-2017, 12:02 PM
unruhjonny's Avatar
wow!
how did i miss this thread!?
@TA455HO - if you could copy and paste your original post into a reply, and let us know what's sold or still available, I for one would be interested.
1970 Formula 400
Old 04-23-2017, 01:51 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Hi Chad, do you still have the 3909030 NOS freon hose available? If so could you PM me?
Thanks.
CB
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 01-01-2022, 05:44 PM
tigertone tigertone is offline
Default 1881371 weights
Hi,
Do u still have the 1881371 weights?
Old 06-19-2023, 04:28 PM
JMR69 JMR69 is offline
Default 482333 - NOS Pair of rear sway bar insulators
Hi, do you still have the 482333 - NOS Pair of rear sway bar insulators - $80?
Thanks,
Jim
