"B" body ring gear vs "A" body ring gear
In a related post I told of blowing out the rear end in our Catalina at the drag strip last week. Finally had a chance to pull the back cover. The spider gears were the weak link, it appears that at least one of the spider gears lost a few teeth.
The ring gear is a 12 bolt [3.42 ratio]. The question is: Is the diameter of the big body 12 bolt the same as for other GM units ? The reason I ask is that I am considering putting a 12 bolt spool in place of the posi unit. I do have some other spider gears that can be put in but I don't want to race with a rebuilt posi unit and risk blowing it out. I am considering a custom built rear end for the Catalina but the spool would be a less expensive alternative and a quick-fix for the immediate time being. Any help is greatly appreciated, Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
The ring gear is the same diameter, can use a 12 bolt spacer, but you can't use a 12 bolt spool. I had a 3.42:1 posi in my '66 GP and it ate up the rear running 12.1 @ 110 MPH. I'd put a 9 inch in it if you're looking to go faster. JMO
BTW, Brad says he'll have some new R&P gears soon to fit that rear......
" Darksiders Rule "
misterp266: thanks for the reply. Question: If the ring gear is the same diameter on 12 bolts then why wouldn't a 12 bolt spool work ?
Thanks, jim
Also, thanks for the news regarding upcoming R&Ps, that would be great.
Thanks, jim
Jim,
I admit I never tried it but I'm assuming the spool would be:
As far as I know only 3.55:1 gears will be available. Primarily targeted to street use. Not sure when, you'd have to ask Brad.
" Darksiders Rule "
misterp266: thanks for the post. I also posted this question in the Race forum. The answer I got over there was that the difference is the ring diameter [which means the pinion is also different].
So you're right, a spool for a conventional [non-Ponitac big car] 12 bolt will not work in a Big Car Pontiac. Thanks for the info, Jim
