EFI Tech All things EFI and making classics modern!
Old 09-10-2023, 10:13 PM
lemans67 lemans67 is offline
Default 3 bad fuel injectors
FAST EZ EFI2. Port injection on an EFI Torker intake. What are the chances of 3 injectors going bad at the same time? My engine with only about 150 miles on it, started running very rough, backfire on decel, rough idle. Changed plugs, they were loaded up. Thought nbr7 plug wire was the issue. Repaired it. Still had issues. Thought I would check the injector and it reads OL. Checked and 2,3 and 7 read open with the rest reading 16ohms. That is the rating. These are Edelbrock injectors. Anything to do other than change injectors? Bad/ old fuel? Thanks
67 LeMans convertible. Tyrol blue, M22z autogear, 2.73 8.5, 455, FAST MPI fuel injection. 243/ 251 112. solid roller. SD performance ported 6x heads.
